The camera occasionally loses a few frames of images during the always-on streaming process
    We are using ORin NX + max9296 + max9295 + Intel D457. During the long-term streaming test at 10fps, we found that a few frames of images were occasionally lost. Here is the trace.log when the frame loss occurred. Could you please help check what might be the cause of this issue?
    kworker/3:1-485227  [003] .... 408873.990724: rtcpu_vinotify_event: tstamp:12778017171526 cch:4 vi:1 tag:FS channel:0x01 frame:0 vi_tstamp:408896540077216 data:0x0000000000000012
     kworker/3:1-485227  [003] .... 408873.990726: rtcpu_vinotify_event: tstamp:12778017171665 cch:4 vi:1 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:408896540077248 data:0x0000000200000000
     kworker/3:1-485227  [003] .... 408873.990727: rtcpu_vinotify_event: tstamp:12778017171818 cch:4 vi:1 tag:CHANSEL_PXL_SOF channel:0x21 frame:0 vi_tstamp:408896540087808 data:0x0000000000000001
     kworker/3:1-485227  [003] .... 408873.990727: rtcpu_vinotify_event: tstamp:12778017171950 cch:4 vi:1 tag:VIFALC_ACTIONLST channel:0x21 frame:0 vi_tstamp:408896540091712 data:0x000000000802e6fe
     kworker/3:1-485227  [003] .... 408873.990728: rtcpu_vinotify_event: tstamp:12778017172099 cch:4 vi:1 tag:VIFALC_TDSTATE channel:0x21 frame:0 vi_tstamp:408896540205600 data:0x759e240010000000
     kworker/3:1-485227  [003] .... 408873.990728: rtcpu_vinotify_event: tstamp:12778017172230 cch:4 vi:1 tag:VIFALC_TDSTATE channel:0x21 frame:0 vi_tstamp:408896540222016 data:0x000000003100e6ff
     kworker/3:1-485227  [003] .... 408873.990729: rtcpu_vinotify_event: tstamp:12778017293511 cch:3 vi:1 tag:CHANSEL_PXL_EOF channel:0x22 frame:0 vi_tstamp:408896553285568 data:0x0000000001df0002
     kworker/3:1-485227  [003] .... 408873.990729: rtcpu_vinotify_event: tstamp:12778017293647 cch:3 vi:1 tag:FE channel:0x00 frame:0 vi_tstamp:408896553286144 data:0x0000000000000022
     kworker/3:1-485227  [003] .... 408873.990729: rtcpu_vinotify_event: tstamp:12778017293807 cch:3 vi:1 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:408896553286176 data:0x0000000400000000
     kworker/3:1-485227  [003] .... 408873.990730: rtcpu_vinotify_event: tstamp:12778017293940 cch:3 vi:1 tag:ATOMP_FRAME_DONE channel:0x22 frame:0 vi_tstamp:408896553286240 data:0x0000000000000000
     kworker/3:1-485227  [003] .... 408873.990730: rtcpu_vinotify_event: tstamp:12778017503808 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:408896554327616 data:0x0000000001df0002
     kworker/3:1-485227  [003] .... 408873.990731: rtcpu_vinotify_event: tstamp:12778017503944 cch:0 vi:0 tag:FE channel:0x03 frame:0 vi_tstamp:408896554328224 data:0x0000000000000021
     kworker/3:1-485227  [003] .... 408873.990731: rtcpu_vinotify_event: tstamp:12778017504105 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:408896554328256 data:0x0000000800000000
     kworker/3:1-485227  [003] .... 408873.990731: rtcpu_vinotify_event: tstamp:12778017504240 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:408896554328288 data:0x0000000000000000
     kworker/3:1-485227  [003] .... 408873.990731: rtcpu_vinotify_event: tstamp:12778017504393 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:408896554345408 data:0x000000000202d9ee
     kworker/3:1-485227  [003] .... 408873.990732: rtcpu_vinotify_event: tstamp:12778017504525 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:408896554350880 data:0x000000000002d9ee
     kworker/3:1-485227  [003] .... 408873.990732: rtcpu_vinotify_event: tstamp:12778017504677 cch:1 vi:0 tag:FS channel:0x02 frame:0 vi_tstamp:408896560011072 data:0x0000000000000011
     kworker/3:1-485227  [003] .... 408873.990732: rtcpu_vinotify_event: tstamp:12778017504814 cch:1 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:408896560011136 data:0x0000000400000000
     kworker/3:1-485227  [003] .... 408873.990732: rtcpu_vinotify_event: tstamp:12778017504969 cch:1 vi:0 tag:CHANSEL_PXL_SOF channel:0x22 frame:0 vi_tstamp:408896560017280 data:0x0000000000000001
     kworker/3:1-485227  [003] .... 408873.990733: rtcpu_vinotify_event: tstamp:12778017505102 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x22 frame:0 vi_tstamp:408896560025152 data:0x000000000802d9f6
     kworker/3:1-485227  [003] .... 408873.990733: rtcpu_vinotify_event: tstamp:12778017641352 cch:3 vi:1 tag:VIFALC_ACTIONLST channel:0x22 frame:0 vi_tstamp:408896553306080 data:0x000000000202e6fe
     kworker/3:1-485227  [003] .... 408873.990733: rtcpu_vinotify_event: tstamp:12778017641488 cch:3 vi:1 tag:VIFALC_ACTIONLST channel:0x22 frame:0 vi_tstamp:408896553311680 data:0x000000000002e6fe
     kworker/3:1-485227  [003] .... 408873.990734: rtcpu_vinotify_event: tstamp:12778017832088 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x22 frame:0 vi_tstamp:408896560139232 data:0x759d520010000000
     kworker/3:1-485227  [003] .... 408873.990734: rtcpu_vinotify_event: tstamp:12778017832224 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x22 frame:0 vi_tstamp:408896560156768 data:0x000000003100d9f7
     kworker/3:1-485227  [003] .... 408873.990734: rtcpu_vinotify_event: tstamp:12778017832375 cch:0 vi:0 tag:FS channel:0x03 frame:0 vi_tstamp:408896567319776 data:0x0000000000000011
     kworker/3:1-485227  [003] .... 408873.990734: rtcpu_vinotify_event: tstamp:12778017832510 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:408896567319840
What’s aways on streaming process?
Can tell the frame lost from the trace log. How do you check the frame lost?
Sorry, we can’t obtain the information about frame loss from the trace.log. Instead, we got it from the dmesg.
[Thu Feb 20 21:34:32 2025] cpufreq: cpu0,cur:1062000,set:729600,set ndiv:57
[Thu Feb 20 21:34:42 2025] cpufreq: cpu0,cur:972000,set:729600,set ndiv:57
[Thu Feb 20 21:34:42 2025] cpufreq: cpu0,cur:1240000,set:1984000,set ndiv:155
[Thu Feb 20 21:35:02 2025] cpufreq: cpu0,cur:1153000,set:729600,set ndiv:57
[Thu Feb 20 21:35:12 2025] cpufreq: cpu4,cur:1833000,set:1984000,set ndiv:155
[Thu Feb 20 21:35:32 2025] cpufreq: cpu0,cur:860000,set:729600,set ndiv:57
[Thu Feb 20 21:35:52 2025] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072, vc: 3
[Thu Feb 20 21:35:52 2025] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072, vc: 1
[Thu Feb 20 21:35:52 2025] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[Thu Feb 20 21:35:52 2025] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072, vc: 0
[Thu Feb 20 21:35:52 2025] (NULL device *): vi_capture_control_message: NULL VI channel received
[Thu Feb 20 21:35:52 2025] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[Thu Feb 20 21:35:52 2025] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[Thu Feb 20 21:35:52 2025] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[Thu Feb 20 21:35:52 2025] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[Thu Feb 20 21:35:52 2025] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 3
[Thu Feb 20 21:35:52 2025] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072, vc: 2
[Thu Feb 20 21:35:52 2025] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 2
[Thu Feb 20 21:36:03 2025] cpufreq: cpu0,cur:1045000,set:729600,set ndiv:57
[Thu Feb 20 21:36:23 2025] cpufreq: cpu0,cur:926000,set:729600,set ndiv:57
[Thu Feb 20 21:36:23 2025] cpufreq: cpu4,cur:1867000,set:1984000,set ndiv:155
[Thu Feb 20 21:37:03 2025] cpufreq: cpu0,cur:967000,set:729600,set ndiv:57
[Thu Feb 20 21:37:23 2025] cpufreq: cpu0,cur:1043000,set:729600,set ndiv:57
[Thu Feb 20 21:37:53 2025] cpufreq: cpu0,cur:728000,set:1984000,set ndiv:155
[Thu Feb 20 21:37:53 2025] cpufreq: cpu0,cur:911000,set:729600,set ndiv:57
[Thu Feb 20 21:38:03 2025] cpufreq: cpu4,cur:846000,set:1036800,set ndiv:81
[Thu Feb 20 21:38:13 2025] cpufreq: cpu0,cur:1041000,set:1984000,set ndiv:155
[Thu Feb 20 21:38:13 2025] cpufreq: cpu0,cur:1679000,set:1984000,set ndiv:155
[Thu Feb 20 21:38:23 2025] cpufreq: cpu0,cur:1836000,set:1984000,set ndiv:155
[Thu Feb 20 21:38:33 2025] cpufreq: cpu0,cur:802000,set:1984000,set ndiv:155
[Thu Feb 20 21:38:33 2025] cpufreq: cpu4,cur:1340000,set:1497600,set ndiv:117
[Thu Feb 20 21:38:43 2025] cpufreq: cpu4,cur:1526000,set:1984000,set ndiv:155
[Thu Feb 20 21:38:53 2025] cpufreq: cpu0,cur:1624000,set:1984000,set ndiv:155
[Thu Feb 20 21:38:53 2025] cpufreq: cpu4,cur:1862000,set:1984000,set ndiv:155
[Thu Feb 20 21:39:03 2025] cpufreq: cpu0,cur:1304000,set:1420800,set ndiv:111
[Thu Feb 20 21:39:33 2025] cpufreq: cpu0,cur:908000,set:1984000,set ndiv:155
Boost the clocks to verify.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
