I’m debuging the camera of Xavier NX 35.2.1.The topology is as following.And the attachment
camera.patch (174.1 KB) is the patch.
when I display the picture of the camera using qv4l2, the camera sometimes has picture and sometimes doesn’t have.Do you have any hint?
hello tianyi2,
may I know the total number of camera in your system.
is it always a specific camera node not sending camera frames, or, this issue is happened randomly?
please also share kernel logs for reference, thanks
There is only one camera every time, and I only init one camera every time.And there is 6 camera position.
This happened randomly in a node but no picture is more. And This is happend in every node.
When there is not a picture,the following is printed and when there is a picture,nothing is printed.
####################log start#####################
[ 5967.838961] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 5967.839235] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 5967.840539] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5967.840717] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 5967.840953] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5967.841109] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[ 5967.841676] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 5970.398977] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 5970.399225] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 5970.400567] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5970.400734] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 5970.400966] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5970.401118] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[ 5970.401727] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 5972.962953] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 5972.963202] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 5972.968622] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5972.968838] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 5972.969086] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5972.969243] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[ 5972.970030] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 5975.519013] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 5975.519315] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 5975.520599] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5975.520812] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 5975.521026] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5975.521192] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[ 5975.521732] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 5978.046972] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 5978.047313] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 5978.048567] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5978.048741] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 5978.048973] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5978.049124] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[ 5978.049630] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 5983.462965] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 5983.463218] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 5983.464550] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5983.464775] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 5983.465037] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5983.465201] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[ 5983.466277] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
hello tianyi2,
it’s NULL VI channel
reported, the video node is not registered correctly.
please try to apply this kernel patch for testing.
diff --git a/drivers/platform/tegra/rtcpu/device-group.c
@@ -51,7 +51,7 @@ static int get_grouped_device(struct camrtc_device_group *grp,
if (pdev == NULL) {
dev_warn(dev, "%s[%u] node has no device\n", name, index);
- return 0;
+ return -EPROBE_DEFER;
After applying the patch, the result is the same.
#########################log start##############################
[ 155.874359] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 155.874660] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 155.875881] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 155.876073] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 155.876328] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 155.876491] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[ 155.878852] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 158.434333] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 158.434582] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 158.439820] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 158.439995] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 158.440212] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 158.440379] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[ 158.441034] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 160.994320] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 160.994619] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 160.995813] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 160.996005] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 160.996191] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 160.996375] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[ 160.996962] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 190.690979] hot-surface-alert cooling state: 1 → 0
#########################log end###############################
hello tianyi2,
may I also confirm the camera hardware setups.
did you keep these six cameras connected before system boot-up?
We have only one camera.
I test the situation that the the one camera is connected before system boot-up and the one camera is connected before i2c init. This two situation have the same result.
The CAM0_PWDN is suspended. Does it have effect on this situation.
hello tianyi2,
is it timing issue? what’s the difference between workable and non-workable scenario.
had you also try adding set_mode_delay_ms
device tree property to configure wait time for the first frame after capture starts. the unit is in milliseconds.
Which node is the set_mode_delay_ms
added under? which value is proper?I haven’t seen the example.
please refer to Sensor Software Driver Programming.
The problem is solved.
I change the serdes_pix_clk_hz in the device tree from 640000000 to 320000000.
