hi, i have a custom object detection model and i want to use it with a python script so that i can connect it with the GPIO later.
the problem is whenever i point the camera to the object i want it to detect it stops working and close without any error. note that
1- the camera is working and i can capture anything as long as that specific object is outside the frame.
2- and the same code will work fine when i use the pre-trained models like ssd-mobilenet-v2 or googlenet
i’ve tried multiple scripts from the tutorials like
import jetson.inference
import jetson.utils
net=jetson.inference.detectNet('SSD-mobilenet-v2',['--model=jetson-inference/python/training/detection/ssd/models/gg/ssd-mobilenet.onnx', '--input-blob=input_0', '--output-cvg=scores', '--output-bbox=boxes', '--label=jetson-inference/python/training/detection/ssd/models/gg/labels.txt'], threshold=0.5)
camera = jetson.utils.videoSource("csi://0")
display = jetson.utils.videoOutput("display://0")
while True:
img = camera.Capture()
detections = net.Detect(img)
ss=''.join(detections)
display.Render(img)
display.SetStatus("Object Detection | Network {:.0f} FPS".format(net.GetNetworkFPS()))
and
import jetson.utils
import argparse
import sys
# parse the command line
parser = argparse.ArgumentParser(description="Locate objects in a live camera stream using an object detection DNN.",
formatter_class=argparse.RawTextHelpFormatter, epilog=jetson.inference.detectNet.Usage() +
jetson.utils.videoSource.Usage() + jetson.utils.videoOutput.Usage() + jetson.utils.logUsage())
parser.add_argument("input_URI", type=str, default="", nargs='?', help="URI of the input stream")
parser.add_argument("output_URI", type=str, default="", nargs='?', help="URI of the output stream")
parser.add_argument("--network", type=str, default="ssd-mobilenet-v2", help="pre-trained model to load (see below for options)")
parser.add_argument("--overlay", type=str, default="box,labels,conf", help="detection overlay flags (e.g. --overlay=box,labels,conf)\nvalid combinations are: 'box', 'labels', 'conf', 'none'")
parser.add_argument("--threshold", type=float, default=0.5, help="minimum detection threshold to use")
is_headless = ["--headless"] if sys.argv[0].find('console.py') != -1 else [""]
try:
opt = parser.parse_known_args()[0]
except:
print("")
parser.print_help()
sys.exit(0)
# load the object detection network
#net = jetson.inference.detectNet(opt.network, sys.argv, opt.threshold)
net=jetson.inference.detectNet(argv=['--model=jetson-inference/python/training/detection/ssd/models/gg/ssd-mobilenet.onnx', '--label=jetson-inference/python/training/detection/ssd/models/gg/labels.txt', '--input-blob=input_0', '--output-cvg=scores', '--output-bbox=boxes'], threshold=0.5)
# create video sources & outputs
input = jetson.utils.videoSource(opt.input_URI, argv=sys.argv)
output = jetson.utils.videoOutput(opt.output_URI, argv=sys.argv+is_headless)
# process frames until the user exits
while True:
# capture the next image
img = input.Capture()
# detect objects in the image (with overlay)
detections = net.Detect(img, overlay=opt.overlay)
# print the detections
print("detected {:d} objects in image".format(len(detections)))
for detection in detections:
print(detection)
# render the image
output.Render(img)
# update the title bar
output.SetStatus("{:s} | Network {:.0f} FPS".format(opt.network, net.GetNetworkFPS()))
# print out performance info
net.PrintProfilerTimes()
# exit on input/output EOS
if not input.IsStreaming() or not output.IsStreaming():
break
