Question:The count information that should be displayed in the upper left corner in deepstream-test3 is not displayed!!!
2.Test:I printed the count in the console and it is there with this text message.
3.Test:In the configuration file I have set display_text to 1 and the label is displayed correctly.
Code:
txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
**g_print ("Frame display_text = %s\n",**
** txt_params->display_text);//This does work**
/* Now set the offsets where the string should appear */
txt_params->x_offset = 10;
txt_params->y_offset = 12;
/* Font , font-color and font-size */
txt_params->font_params.font_name = "Serif";
txt_params->font_params.font_size = 10;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 1.0;
txt_params->font_params.font_color.blue = 1.0;
txt_params->font_params.font_color.alpha = 1.0;
/* Text background color */
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.0;
txt_params->text_bg_clr.alpha = 1.0;
**nvds_add_display_meta_to_frame(frame_meta, display_meta);**//This does not seem to work
By default deepstream-test3 disables OSD display. You can enable the display by setting “OSD_DISPLAY_TEXT” to 1 (current value is 0) and uncomment the code in function tiler_src_pad_buffer_probe.
Thanks for your reply.
I have sat the operation you said, but about the display of the count, it does not show.
This function “nvds_add_display_meta_to_frame(frame_meta, display_meta) “ does not work in deepstream-test3
