- deepstream-app version 6.1.0
- DeepStreamSDK 6.1.0
- CUDA Driver Version: 11.4
- CUDA Runtime Version: 11.0
- TensorRT Version: 8.2
- cuDNN Version: 8.4
- libNVWarp360 Version: 2.0.1d3
- on A6000
1, I added ros publishing to the ds-example plugin to publish the cv::mat video data in it, but the data seems to be compressed and the display in ros has been completely changed.
2, My test: adding a temporary image to the publish is fine, but to publish the mat from the ds-example is problematic.
3, Here is the relevant code and the effect image in the gst_dsexample_transform_ip function.
#ifdef WITH_OPENCV
cv::Mat in_mat;
if (dsexample->blur_objects) {
/* Map the buffer so that it can be accessed by CPU */
if (surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0] == NULL){
if (NvBufSurfaceMap (surface, frame_meta->batch_id, 0, NVBUF_MAP_READ_WRITE) != 0){
GST_ELEMENT_ERROR (dsexample, STREAM, FAILED,
("%s:buffer map to be accessed by CPU failed", __func__), (NULL));
return GST_FLOW_ERROR;
/* Cache the mapped data for CPU access */
if(dsexample->inter_buf->memType == NVBUF_MEM_SURFACE_ARRAY)
NvBufSurfaceSyncForCpu (surface, frame_meta->batch_id, 0);
in_mat =
cv::Mat (surface->surfaceList[frame_meta->batch_id].planeParams.height[0],
surface->surfaceList[frame_meta->batch_id].planeParams.width[0], CV_8UC4,
surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0],
surface->surfaceList[frame_meta->batch_id].planeParams.pitch[0]);
#endif
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next)
obj_meta = (NvDsObjectMeta *) (l_obj->data);
/* gaussian blur the detected objects using opencv */
#ifdef WITH_OPENCV
/* if (blur_objects (dsexample, frame_meta->batch_id,
&obj_meta->rect_params, in_mat) != GST_FLOW_OK) {
("blurring the object failed"), (NULL));
if (NvBufSurfaceUnMap (surface, frame_meta->batch_id, 0)){
("%s:buffer unmap to be accessed by CPU failed", __func__), (NULL));
g_print ("%s %d\n","frame_meta:id=",frame_meta->source_id);
if(frame_meta->source_id==0){
if(blur_objects (dsexample, frame_meta->batch_id,
&obj_meta->rect_params, in_mat) == GST_FLOW_OK){
//cv::Mat img=cv::imread("/home/fast-cnn-train/CODES/车辆数据/车辆数据集/data8/test/images/bigcar_002.jpg");
sensor_msgs::ImagePtr msg = cv_bridge::CvImage(std_msgs::Header(), "bgr8", in_mat).toImageMsg(); //cvmat格式转ros ImagePtr格式
pub.publish(msg);//ros发布
else{
