The debug_log lead to preprocess plugin seg fault
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.1
• TensorRT Version 8.2.5-1+cuda11.4
• NVIDIA GPU Driver Version (valid for GPU only) 510.68.02
• Issue Type( questions, new requirements, bugs) questions
export GST_DEBUG=5
When i export GST_DEBUG=5, the ds-app start to print debug log. But it make a Segmentation fault in the preprocess plugin. I add some prints , and found it may core dump at a debug log.
Here is some debug log:
I run the code in a docker image : nvcr.io/nvidia/deepstream:6.1-devel
When i found it may this log lead to core dump , i annotation this log . It can work normaly.
Wait for your answer. thanks
Which demo did you run, our demo or your own demo?
Could you help to use our demo to repro this crash problem?
i run the deepstream-app program
here is the app config file :
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=3
uri=file:/work/deepstream-6.1-origin/samples/streams/sample_1080p_h264.mp4
#uri=rtsp://admin:zhy12345@172.16.72.64:554/Streaming/Channels/101
#uri=rtmp://192.168.0.14:1935/live/live999
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay 8=rtmpStreaming
type=8
source-id=0
#Indicates how fast the stream is to be rendered. 0: As fast as possible 1: Synchronously
sync=0
gpu-id=0
nvbuf-memory-type=0
codec=1
enc-type=0
qos=0
bitrate=4000000
iframeinterval=30
#rtsp-port=8857
#udp-port=5400
rtmp-address=192.168.0.87
rtmp-port=26666
[sink4]
enable=1
type=6
topic=yolo-meta-app-custom
msg-conv-config=dstest5_msgconv_sample_config.txt
msg-conv-msg2p-new-api=1
msg-conv-payload-type=257
msg-conv-msg2p-lib=/work/deepstream/sources/libs/zhy_nvmsgconv/libzhy_nvds_msgconv.so
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-6.1/lib/libnvds_redis_proto.so
msg-broker-conn-str=192.168.0.87;36379
[osd]
enable=1
gpu-id=0
border-width=5
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
label-file=./deepStream-Yolo-zhy/labels.txt
count-ids=0;2
opencv-img-save=0
save-interval=10
save-img-path=/work/
[streammux]
gpu-id=0
#Boolean property to inform muxer that sources are live
live-source=1
batch-size=1
#time out in usec, to wait after the first buffer is available
#to push the batch even if the complete batch is not formed
batched-push-timeout=40000
set muxer output width and height
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
batch-size=4
gie-unique-id=1
nvbuf-memory-type=3
input-tensor-meta=1
config-file=config_infer_primary_yoloV5.txt
[pre-process]
enable=1
gpu-id=0
config-file=config_preprocess.txt
[tests]
file-loop=1
The preprocess config file is:
[property]
enable=1
target-unique-ids=1
# 0=NCHW, 1=NHWC, 2=CUSTOM
network-input-order=0
# if enabled maintain the aspect ratio while scaling
maintain-aspect-ratio=1
# if enabled pad symmetrically with maintain-aspect-ratio enabled
symmetric-padding=1
# processig width/height at which image scaled
processing-width=960
processing-height=960
scaling-buf-pool-size=6
tensor-buf-pool-size=6
# tensor shape based on network-input-order
network-input-shape= 4;3;960;960
# 0=RGB, 1=BGR, 2=GRAY
network-color-format=0
# 0=FP32, 1=UINT8, 2=INT8, 3=UINT32, 4=INT32, 5=FP16
tensor-data-type=0
tensor-name=data
# 0=NVBUF_MEM_DEFAULT 1=NVBUF_MEM_CUDA_PINNED 2=NVBUF_MEM_CUDA_DEVICE 3=NVBUF_MEM_CUDA_UNIFIED
scaling-pool-memory-type=0
# 0=NvBufSurfTransformCompute_Default 1=NvBufSurfTransformCompute_GPU 2=NvBufSurfTransformCompute_VIC
scaling-pool-compute-hw=0
# Scaling Interpolation method
# 0=NvBufSurfTransformInter_Nearest 1=NvBufSurfTransformInter_Bilinear 2=NvBufSurfTransformInter_Algo1
# 3=NvBufSurfTransformInter_Algo2 4=NvBufSurfTransformInter_Algo3 5=NvBufSurfTransformInter_Algo4
# 6=NvBufSurfTransformInter_Default
scaling-filter=0
custom-lib-path=/work/deepstream/sources/gst-plugins/gst-nvdspreprocess/nvdspreprocess_lib/libcustom2d_preprocess.so
custom-tensor-preparation-function=CustomTensorPreparation
[user-configs]
pixel-normalization-factor=0.003921568
#mean-file=
#offsets=
[group-0]
src-ids=0
custom-input-transformation-function=CustomAsyncTransformation
process-on-roi=1
roi-params-src-0=200;200;1000;600
The pgie config file is:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
custom-network-config=/work/deepstream/sources/apps/sample_apps/deepstream-app/deepStream-Yolo-zhy/best.cfg
#model-file=best.wts
model-engine-file=…/model_b4_gpu0_fp16.engine
#model-engine-file=wurenji_1121.engine
#int8-calib-file=int8calib.table
labelfile-path=labels.txt
batch-size=1
network-mode=2
num-detected-classes=1
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
input-tensor-from-meta=1
parse-bbox-func-name=NvDsInferParseYolo
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.25
@jiangyuzhe1992 , Thanks for your debugging, it’s a code error. Cause it’s open source, you can modify it by
    GST_DEBUG_OBJECT (nvdspreprocess, "parsed user-config key = %s value = %s\n", *key, val.c_str());
We’ll update it in the future version.
thanks for your reply.
