What is the difference between .qdrep and nsys-rep after profiling a python code?
.qdrep
was the former extension of the report file. It was replaced by .nsys-rep
with release 2021.4.
Result file rename
- In order to make the Nsight tools family more consistent, all versions of Nsight Systems starting with 2021.4 will use the “.nsys-rep” extension for generated report files by default.
- Older versions of Nsight Systems used “.qdrep”.
- Nsight Systems GUI 2021.4 and higher will continue to support opening older “.qprep” reports.
- Versions of Nsight Systems GUI older than 2021.4 will not be able to open “.nsys-rep” reports.
