We bought this AGX Orin one month ago. While the Samsung T7 SSD (mounted at /mnt/ssd) was under heavy I/O on the Jetson AGX, a USB headphone was hot-plugged into the AGX. The AGX’s power rail dipped (“power jumped”), the system reset, and after reboot the T7 was no longer visible via lsblk or lsusb
We spent hours to debug. As md file could not be uploaded and I pasted the content below. I believe this is the hardware issue. Please let me know your help.
AGX Type-C USB Port Troubleshooting — 2026-07-05
Incident
While the Samsung T7 SSD (mounted at /mnt/ssd) was under heavy I/O on the Jetson AGX, a USB headphone was hot-plugged into the AGX. The AGX’s power rail dipped (“power jumped”), the system reset, and after reboot the T7 was no longer visible via lsblk or lsusb.
Hardware involved
- Host: NVIDIA Jetson AGX (aarch64, Tegra xHCI controller, onboard Realtek USB 2.0 + USB 3.0 hubs on the USB-A port banks)
- Drive: Samsung Portable SSD T7, 1 TB, ext4, USB-to-NVMe bridge (appears as NVMe over USB)
- Filesystem: ext4 partition with fstab entry
UUID=cd424d23-… /mnt/ssd ext4 defaults,nofail 0 2
Diagnostic timeline
1. Initial state — T7 invisible
lsblkshowed only the internal eMMC.lsusbshowed no mass-storage device; only Bluetooth radio + two Realtek hubs.- No USB enumeration events in the kernel log.
fstabhadnofail, which is why boot completed without the drive.
2. Isolation tests
- Test A — USB 2 thumb drive in the same AGX port → works. AGX port itself is not dead.
- Test B — T7 on DGX Spark → works. Enumerates cleanly. T7 hardware is fine.
- SMART on Spark: Overall health PASSED, 0x00 critical warnings, 0% wear, 0 media errors, only
Unsafe Shutdownscounter ticked (cosmetic). Drive is healthy. - GNOME Disks red-X badge: caused by the unclean ext4 flag after the brownout mid-write.
fsck -fycleaned any journal issues; the red X was a stale udisks2 badge, harmless.
3. AGX enumeration attempts
Cold power cycle (60 s brick unplug) alone did not bring the T7 back on the AGX.
Direct USB-A → T7 initial attempt: no enumeration.
Unpowered USB 3 hub → T7 fell back to USB-C Billboard mode on Bus 1 (USB 2.0). The unpowered hub could not deliver enough current for the T7 to bring up its SuperSpeed PHY. Cannot solve a power problem with an unpowered hub.
Powered Dell dock → T7 enumerated at SuperSpeed on usb 2-3.4 as /dev/sda. Data intact.
4. Port-by-port verification (three dmesg logs)
| Port | Kernel event on T7 plug-in | Result |
| Type-A USB 2 (via Dell dock) | usb 2-3.4: new SuperSpeed → PSSD T7 → sda |
✅ Works |
| Type-A USB 3 (direct, blue) | usb 2-3.2: new SuperSpeed Plus Gen 2x1 → PSSD T7 → sda |
✅ Works at 10 Gbps native |
| Type-C | No event at all | ❌ Fails |
Direct-to-blue-USB-A working at Gen 2x1 disproved the earlier hypothesis that the AGX SuperSpeed side was globally damaged. The AGX’s USB 3 SuperSpeed on USB-A ports is fine.
5. Type-C port narrowed down
Follow-up tests on the type-C port:
- T7 plugged into type-C → blue LED constant (VBUS = 5 V is supplied) but no kernel event.
- USB 2 thumb drive plugged into type-C → enumerates and mounts.
This locates the failure precisely:
- VBUS supply: working (T7 gets power)
- CC lines (device detection): working (thumb drive is detected)
- D+/D- (USB 2 data pair): working (thumb drive works)
- SuperSpeed TX/RX pairs: not working (T7’s SS bridge cannot link-train)
Root cause
The brownout event during the hot-plug damaged the type-C port’s SuperSpeed mux/redriver IC (the small chip that handles cable-orientation flip and 10 Gbps signal amplification for the SS lanes on USB-C connectors). USB 2.0 D+/D- pins bypass this IC entirely — that’s why USB 2 devices still work on the same port. USB-A ports don’t have such a mux at all, which is why they were unaffected.
The Samsung T7 uses a SuperSpeed-only USB-to-NVMe bridge — if SS link training fails, the T7 stays powered but does not fall back to USB 2.0 storage mode. That’s why the T7 appears completely silent on the type-C port while a USB 2 thumb drive works there.
The T7 drive itself is 100% healthy (SMART + fsck confirmed). The initial “unsafe shutdown” counter is cosmetic and expected.
Working configuration
- Use the Type-A USB 3 (blue) port for the T7. Native 10 Gbps SuperSpeed Plus Gen 2x1, no hub needed.
- Fstab entry at
/mnt/ssdcontinues to work;sudo mount /mnt/ssd(orsudo mount -a) mounts after boot since the drive is not present at boot time. - Type-C port remains usable for USB 2.0 peripherals only.
Preventive measures
- Do not hot-plug USB devices while the SSD is under I/O. Add peripherals when the drive is idle.
- Consider a UPS or better-regulated PSU for the AGX to protect against future rail transients.
- If long-term reliability matters, keep the T7 behind a powered USB 3 hub so the drive is on a clean, isolated 5 V rail — future AGX brownouts won’t reach the drive.
- If type-C SuperSpeed is needed for other peripherals (DP-alt display, other SS devices), the AGX carrier board would need repair/RMA. For the T7 alone, the type-A workaround is a complete fix.
Commands used
# Inspection
lsblk -o NAME,SIZE,TYPE,MOUNTPOINT,FSTYPE,MODEL
lsusb
lsusb -t
ls -la /dev/disk/by-id/ /dev/disk/by-uuid/
# Filesystem repair (on Spark, T7 unmounted)
sudo fsck -fy /dev/sdXN
# SMART inspection (whole disk, not partition)
sudo smartctl -a /dev/sdb
# Kernel log during plug events
sudo dmesg -w
