The document has no map_rep.py file
https://docs.nvidia.com/networking/display/public/sol/qsg+for+high+availability+with+nvidia+enhanced+sr-iov+with+bonding+support+(vf-lag)
" First download attached map_rep.py script from this section and run it as explained here: map_rep.py"
The map_rep.py does not exist!
Thank you for letting us know!
I’ll pass the information on.
OK,can you provide the man_rep.py file as soon as possible, and i need check the environment by using it.
Sorry, I cannot.
I contacted the document author and asked for help, but I cannot give you more information than that.
The file will hopefully be supplied through the document you linked above at some point.
