I have three kernels to add two vectors of float as showed in the below:
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include <stdio.h>
#define THREAD_PER_BLOCK 256
#define FETCH_FLOAT2(pointer) (reinterpret_cast<float2*>(&(pointer))[0])
#define FETCH_FLOAT4(pointer) (reinterpret_cast<float4*>(&(pointer))[0])
__global__ void add(float* a, float* b, float* c)
int idx = threadIdx.x + blockIdx.x * blockDim.x;
c[idx] = a[idx] + b[idx];
__global__ void vec2_add(float* a, float* b, float* c)
int idx = (threadIdx.x + blockIdx.x * blockDim.x) * 2;
float2 reg_a = FETCH_FLOAT2(a[idx]);
float2 reg_b = FETCH_FLOAT2(b[idx]);
float2 reg_c;
reg_c.x = reg_a.x + reg_b.x;
reg_c.y = reg_a.y + reg_b.y;
FETCH_FLOAT2(c[idx]) = reg_c;
__global__ void vec4_add(float* a, float* b, float* c)
int idx = (threadIdx.x + blockIdx.x * blockDim.x) * 4;
float4 reg_a = FETCH_FLOAT4(a[idx]);
float4 reg_b =FETCH_FLOAT4(b[idx]);
float4 reg_c;
reg_c.z = reg_a.z + reg_b.z;
reg_c.w = reg_a.w + reg_b.w;
FETCH_FLOAT4(c[idx]) = reg_c;
int main() {
const int N = 32 * 1024 * 1024;
float* a = (float*)malloc(N * sizeof(float));
float* b = (float*)malloc(N * sizeof(float));
float* out = (float*)malloc(N * sizeof(float));
float* d_a;
float* d_b;
float* d_out;
cudaMalloc((void**)&d_a, N * sizeof(float));
cudaMalloc((void**)&d_b, N * sizeof(float));
cudaMalloc((void**)&d_out, N * sizeof(float));
float* res = (float*)malloc(N * sizeof(float));
for (int i = 0; i < N; i++) {
a[i] = 1;
b[i] = i;
res[i] = a[i] + b[i];
cudaMemcpy(d_a, a, N * sizeof(float), cudaMemcpyHostToDevice);
cudaMemcpy(d_b, b, N * sizeof(float), cudaMemcpyHostToDevice);
dim3 Grid(N / THREAD_PER_BLOCK / 4, 1);
dim3 Block(THREAD_PER_BLOCK, 1);
int iter = 2000;
for (int i = 0; i < iter; i++) {
vec4_add << <Grid, Block >> > (d_a, d_b, d_out);
cudaMemcpy(out, d_out, N * sizeof(float), cudaMemcpyDeviceToHost);
if (check(out, res, N)) printf("the ans is right\n");
else printf("the ans is wrong\n");
free(a);
free(b);
free(out);
free(res);
cudaFree(d_a);
cudaFree(d_b);
cudaFree(d_out);
return 0;
I use them to add two vectors of float of which the size is 32 * 1024 * 1024 on my 3060 GPU. And I use Nsight Compute to measure the elapsed time. I expect the elasped time is vec4_add < vec2_add < add since the load and store should be more efficient. But the fact is that vec4_add(2.51ms) > vec2_add(2.28ms) > add(1.93ms), is it reasonable?
