The engine plan file is not compatible with this version of TensorRT, expecting library version 5.1....
The engine plan file is not compatible with this version of TensorRT, expecting library version 5.1.2 got 5.1.5,please rebuild!!!
run ldd program command and result as follows:
libnvinfer.so.5 => /home/ouzh/downloads/TensorRT-5.1.2.2/targets/x86_64-linux-gnu/lib/libnvinfer.so.5 (0x00007fac3b57d000)
link 5.1.2,but why got 5.1.5?
solved
How did you solve the problem?
Ensure the same version of TensorRT when building and running the engine!
Built it on 5.1.5 and running it on 5.1.5. Still gives me the same error.
I built it on 8.0.1.6 and also running it on 8.0.1.6. But I am getting the same error
Hi ,
We recommend you to check the supported features from the below link.
You can refer below link for all the supported operators list.
For unsupported operators, you need to create a custom plugin to support the operation
I dont have CuDnn on my system. Could this be the reason for this error?
