The enqueue() method has been deprecated when used with engines built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag
Description
A clear and concise description of the bug or issue.
Environment
TensorRT Version: 8.4.1.5
GPU Type: 1660 Ti
Nvidia Driver Version: 515.65.01
CUDA Version: 11.7
CUDNN Version: 8.5.0
Operating System + Version: Linux 5.15.0-46-generic #49~20.04.1-Ubuntu
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
I converted a model via /usr/src/tensorrt/bin/trtexec command succesfully. But When I want to run project, for every inference it generates these messages:
[W] [TRT] The enqueue() method has been deprecated when used with engines built from a network created with
 NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. Please use enqueueV2() instead.
How could I disable these messages? My project has been wrote in C++.
You can modify the ProfileVerbosity level to remove warning messages. Please refer to the following doc.
https://docs.nvidia.com/deeplearning/tensorrt/api/c_api/classnvinfer1_1_1_i_logger.html
Thank you.
Changing class Logger : public nvinfer1::ILogger as follows:
public:
    nvinfer1::ILogger::Severity profile_severity_level;
public:
    Logger(Severity severity = Severity::kWARNING)
        : mReportableSeverity(severity)
        json config_json;
        std::ifstream config("../../Configuration.json");
        config >> config_json;
        profile_severity_level = config_json["ProfileSeverityLevel"];
    void log(Severity severity, const char* msg) noexcept override
        switch (profile_severity_level)
        case nvinfer1::ILogger::Severity::kINTERNAL_ERROR: //0
            if (severity != Severity::kERROR && severity != Severity::kWARNING &&
                    severity != Severity::kINFO && severity != Severity::kVERBOSE)
                std::cout << msg << std::endl;
                LogStreamConsumer(mReportableSeverity, severity) << "[TRT] " <<
        std::string(msg) << std::endl;
            break;
        case nvinfer1::ILogger::Severity::kERROR: //1
            if (severity != Severity::kWARNING && severity != Severity::kINFO
            break;
        case nvinfer1::ILogger::Severity::kWARNING: //2
            if (severity != Severity::kINFO && severity != Severity::kVERBOSE)
            break;
        case nvinfer1::ILogger::Severity::kINFO: //3
            if (severity != Severity::kVERBOSE)
            break;
        case nvinfer1::ILogger::Severity::kVERBOSE: //4
            break;
