"The file in the series have unsupported 3 dimensions." - SITK error
Hello Everyone,
We encounter the below issue when we try to trigger our workflow by sending an input test image for our model.
Our model was trained on BRATS dataset. We are trying to do a E2E workflow using claradeploy.
So we have converted the input test image from native .nii file to .dcm file (of shape 240,240,155). We are aware of the channel constarint (4 channels) with BRATS dataset, so we have retained only one channel (data[:,:,:,0]).
nii file shape is - 240,240,155,4
dcm file shape is 240,240,155
model was trained on 240,240,155 as well
When we use of our test image (.dcm file) to trigger the workflow (by sending it to dicom modality in ORTHANC), it fails in the dicom-reader stage. I mean there is an error while converting the dicom to mhd format. This leads to no output from Clara which is expected. Can you help us with this issue?
Has anyone else encountered the same issue? Please note we are using old version of clara.(0.1.8)
"sitk::ERROR: The file in the series have unsupported 3 dimensions."
I am also attaching the Dicom tags information for our dicom file
(0008|0008) = = “ORIGINAL\PRIMARY\VOLUME\NONE”
(0008|0016) = = “1.2.840.10008.5.1.4.1.1.130”
(0008|0018) = = “2.25.268344867590623757739343791212928671539”
(0008|0020) = = “20190714”
(0008|0023) = = “20190714”
(0008|002a) = = "19700101070000 "
(0008|0030) = = “172248”
(0008|0033) = = “173525”
(0008|0050) = = " "
(0008|0060) = = “PT”
(0008|0070) = = "UNKNOWN "
(0008|0090) = = “”
(0008|1030) = = "UNKNOWN "
(0008|103e) = = "UNKNOWN "
(0008|1090) = = "UNKNOWN "
(0008|9205) = = “MONOCHROME”
(0008|9206) = = “VOLUME”
(0008|9207) = = "VOLUME_RENDER "
(0010|0010) = = “abcd”
(0010|0020) = = “2000”
(0010|0030) = = " "
(0010|0040) = = “Male”
(0018|0050) = = "1 "
(0018|0071) = = “MANU”
(0018|0073) = = “MANU”
(0018|1000) = = "UNKNOWN "
(0018|1020) = = "UNKNOWN "
(0018|1134) = = “STATIC”
(0018|1181) = = “NONE”
(0018|2005) = = "-78-77-76-75-74-73-72-71-70-69-68-67-66-65-64-63-62-61-60-59-58-57-56-55-54-53-52-51-50-49-48-47-46-45-44-43-42-41-40-39-38-37-36-35-34-33-32-31-30-29-28-27-26-25-24-23-22-21-20-19-18-17-16-15-14-13-12-11-10-9-8-7-6-5-4-3-2-1
(0008|0050) = = " "
(0008|0090) = = “”
(0010|0030) = = " "
(0018|2005) = = "-78-77-76-75-74-73-72-71-70-69-68-67-66-65-64-63-62-61-60-59-58-57-56-55-54-53-52-51-50-49-48-47-46-45-44-43-42-41-40-39-38-37-36-35-34-33-32-31-30-29-28-27-26-25-24-23-22-21-20-19-18-17-16-15-14-13-12-11-10-9-8-7-6-5-4-3-2-1\0\1\2\3\4\5\6\7\8\9\10\11\12\13\14\15\16\17\18\19\20\21\22\23\24\25\26\27\28\29\30\31\32\33\34\35\36\37\38\39\40\41\42\43\44\45\46\47\48\49\50\51\52\53\54\55\56\57\58\59\60\61\62\63\64\65\66\67\68\69\70\71\72\73\74\75\76 "
(0018|9004) = = “RESEARCH”
(0018|9073) = = “0”
(0018|9725) = = “CYLINDRICAL_RING”
(0018|9726) = = “0”
(0018|9727) = = “0”
(0018|9755) = = "FALSE "
(0018|9758) = = “NO”
(0018|9759) = = “NO”
(0018|9760) = = “NO”
(0018|9761) = = “NO”
(0018|9762) = = “NO”
(0018|9763) = = “NO”
(0018|9764) = = “NO”
(0018|9765) = = “NO”
(0018|9766) = = “NO”
(0018|9767) = = “NO”
(0018|9768) = = “NO”
(0020|000d) = = “1.2.826.0.1.3680043.2.1125.4082960453717943603603726631811946355”
(0020|000e) = = “1.2.826.0.1.3680043.2.1125.8397261186222101954520583083004172948”
(0020|0010) = = " "
(0020|0011) = = “”
(0020|0013) = = "0 "
(0020|0032) = = "-120-120-78 "
(0020|0037) = = "0.99999999999999\0\0\0\0.99999999999999\0 "
(0020|0052) = = “2.25.183387019459409372524007875133033107487”
(0020|1040) = = “”
(0028|0002) = = “1”
(0028|0004) = = "MONOCHROME2 "
(0028|0008) = = "155 "
(0028|0010) = = “240”
(0028|0011) = = “240”
(0028|0030) = = "1\1 "
(0028|0100) = = “16”
(0028|0101) = = “16”
(0028|0102) = = “15”
(0028|0103) = = “0”
(0028|0106) = = “0”
(0028|0107) = = “2213”
(0028|0108) = = “0”
(0028|0109) = = “2213”
(0028|0301) = = “NO”
(0028|1050) = = “1106.5”
(0028|1051) = = “2213”
(0028|2110) = = “00”
(0054|0202) = = “STATIONARY”
(0054|1002) = = “EMISSION”
(0054|1210) = = "0 "
(2050|0020) = = “IDENTITY”
Image Size: (240, 240, 155)
Image PixelType: 16-bit unsigned integer
0123456789012345678901234567890123456789012345678901234567890123456 "
(0018|9073) = = “0”
(0018|9726) = = “0”
(0018|9727) = = “0”
(0020|0010) = = " "
(0020|0011) = = “”
(0008|0050) = = " "
(0008|0090) = = “”
(0010|0030) = = " "
(0018|9073) = = “0”
(0018|9726) = = “0”
(0018|9727) = = “0”
(0020|0010) = = " "
(0020|0011) = = “”
(0020|1040) = = “”
(0028|0002) = = “1”
(0028|0103) = = “0”
(0028|0106) = = “0”
(0028|0108) = = “0”
(0008|0050) = = " "
(0008|0090) = = “”
(0010|0030) = = " "
(0018|9073) = = “0”
(0018|9726) = = “0”
(0018|9727) = = “0”
(0020|0010) = = " "
(0020|0011) = = “”
(0020|1040) = = “”
(0028|0002) = = “1”
(0028|0103) = = “0”
(0028|0106) = = “0”
(0028|0108) = = “0”
(0008|0050) = = " "
(0008|0090) = = “”
(0010|0030) = = " "
(0018|9073) = = “0”
(0018|9726) = = “0”
(0018|9727) = = “0”
(0020|0010) = = " "
(0020|0011) = = “”
(0020|1040) = = “”
(0028|0002) = = “1”
(0028|0103) = = “0”
(0028|0106) = = “0”
(0028|0108) = = “0”
(0008|0050) = = " "
(0008|0090) = = “”
(0010|0030) = = " "
(0018|9073) = = “0”
(0018|9726) = = “0”
(0018|9727) = = “0”
(0020|0010) = = " "
(0020|0011) = = “”
(0020|1040) = = “”
(0028|0002) = = “1”
(0028|0103) = = “0”
(0028|0106) = = “0”
(0028|0108) = = “0”
.99999999999999
(0008|0050) = = " "
(0008|0090) = = “”
(0010|0030) = = " "
(0018|9073) = = “0”
(0018|9726) = = “0”
(0018|9727) = = “0”
(0020|0010) = = " "
(0020|0011) = = “”
(0020|1040) = = “”
(0028|0002) = = “1”
(0028|0103) = = “0”
(0028|0106) = = “0”
(0028|0108) = = “0”
(0020|1040) = = “”
(0028|0002) = = “1”
(0028|0030) = = "1 "
(0028|0103) = = “0”
(0028|0106) = = “0”
(0028|0108) = = “0”
Please note that our original file was in .nii format (240,240,155,4) which was then converted to .dcm file (240,240,155)
When we did the conversion the below tags were empty but I manually added them using pydicom
Request you to let us know for any more information
