ok, so back to your original topic. Is flash.sh in those folders? If it is ,then this issue could be closed.
Related topics
| Boot NVIDIA Jetson-tx2 from existing external drive | 3 | 532 | October 18, 2021 | |
| Flash TX2 with SD card | 35 | 7879 | October 18, 2021 | |
| How can we flash everything apart bootloader to extern sdcard on tx2 like jetson nano(with no intern... | 20 | 8236 | October 18, 2021 | |
| how to make jetson tx2 root file system always run from external ssd hard disk? | 25 | 3296 | September 8, 2021 | |
| Flashing Jetson TX2 for use with Auvidea J120 carrier board | 5 | 1947 | March 15, 2018 | |
| How can I solve ./flash.sh command | 4 | 1012 | October 18, 2021 | |
| Jetpack 4.2.1 TX2 Dev Kit use SSD as boot drive | 11 | 2071 | October 18, 2021 | |
| ./flash.sh? Where should it be? | 3 | 672 | October 18, 2021 | |
| Flash ONLY bootloader on Jetson tx2 with external SSD | 11 | 1893 | October 18, 2021 | |
| How to flash everything apart bootloader to extern sdcard on tx2? | 1 | 392 | August 15, 2019 |
