Hi All,
The frame rate can only be output once, and it cannot be output after that.Could you help me figure out what’s going on?
Problem phenomenon:
root@tegra:/home/robot# v4l2-ctl -d /dev/video0 --set-ctrl sensor_mode=1 --set-fmt-video=width=1920,height=1536 --stream-mmap
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.00 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<^C
root@tegra:/sys/kernel/debug/dynamic_debug# v4l2-ctl -d /dev/video0 --set-ctrl sensor_mode=1 --set-fmt-video=width=1920,height=1536 --stream-mmap
^C^C^C^C^C^C
Block Diagram:
CPU:
Orin NX
isx031 bandwidth 4.3G
software:
root@tegra:/sys/kernel/debug/dynamic_debug# cat /etc/nv_tegra_release
# R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
dts:
dts.txt (485.1 KB)
robot@tegra:~$ v4l2-ctl --list-formats-ext --device /dev/video0
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1920x1536
Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 1920x1280
Size: Discrete 1920x1380
Size: Discrete 1920x1440
Size: Discrete 1600x1300
[1]: 'YUYV' (YUYV 4:2:2)
