The frame rate output by the camera is only half
Hi,nvidia teams:
our board use jetpack 4.4. we found a camera frame rate is only half sometimes, a 30Hz camera only output 15Hz,if I restart my camera application, it will return to normal, I upload the treace and dmesg log in the attachment, and I use the following command to generate “gw5X-21676.txt”, “gw5X-22359.txt”:
grep -r gw5X-21676 trace_1227.txt |grep sof > gw5X-21676.txt
grep -r gw5X-22359 trace_1227.txt |grep sof > gw5X-22359.txt
from “gw5X-21676.txt”, you can see, it is only 15Hz, so have you encountered this problem before?
dmesg_1227.txt (148.7 KB)
gw5X-21676.txt (39.4 KB)
gw5X-22359.txt (78.9 KB)
trace_1227.txt (3.6 MB)
Suppose it could be sensor driver issue.
You can modify the control function(CID) in sensor driver as dummy function to confirm which once cause the problem.
