I use this code to convert my tensorflow model to uff
import uff
uff.from_tensorflow_frozen_model("frozen_inference_graph.pb",
output_nodes=["NMS"],
output_filename="frozen.uff",
preprocessor='config.py'
But I found that the file ‘config.py’ does not run before create uff file which causes failure.
I read the ‘conversion_helpers.py’ located in
/usr/local/lib/python2.7/dist-packages/uff/converters
I found that the function ‘from_tensorflow’ did not process the file ‘config.py’, and what should I do?
