I installed the newest grouped_gemm (v0.1.4) and test it with several groups of tensor loaded on multiple-gpu environments(8*a100), the program errors:
Group_1:
RuntimeError: CUDA error: CUBLAS_STATUS_NOT_INITIALIZED when calling
cublasCreate(handle)
Group_2…n:
RuntimeError: CUDA error: an illegal memory access was encountered
CUDA kernel errors might be asynchronously reported at some other API call, so the stacktrace below might be incorrect.
For debugging consider passing CUDA_LAUNCH_BLOCKING=1.
Compile withTORCH_USE_CUDA_DSA
to enable device-side assertions.
Compared with the original and official tests, the only change is the specified device in this test. The detailed script is bellow and the related device settings are in function rands().
Does it mean the grouped_gemm doesn’t support multi-gpu setting?
import unittest
import itertoolsfrom absl.testing import parameterized
import sys
#sys.path.append(‘/mnt/pfs-guan-ssai/nlu/lizr/zhanjiqing/operator_optimize/lizr/chenxingru/cases/grouped_gemm_base/’)
from grouped_gemm import ops
import numpy as np
import torchdef allclose(x, y, pct=2.0):
mask = torch.isclose(x, y, rtol=1e-5)
pct_diff = (mask.numel() - mask.sum()) / mask.numel() * 100
if pct_diff > pct:
print(x[torch.logical_not(mask)], y[torch.logical_not(mask)])
print(“{:.2f}% of values not close.”.format(pct_diff))
return False
return Truedef add_transpose_flags(x):
out =
for y in x:
for f in [(False,), (True,)]:
out.append(y + f)
return out_TEST_PROBLEMS = add_transpose_flags((
(1, 128, 128, 128),
(8, 128, 128, 128),
(16, 128, 128, 128),
(1, 128, 256, 512),
(8, 128, 256, 512),
(16, 128, 256, 512),
))def randn(bs, x, y, device_id):
out = (torch.rand(bs, x, y) - 0.5 * 2) / (y * x)
device = torch.device(“cuda:%d”%device_id if torch.cuda.is_available() else “cpu”)
return out.to(device).to(torch.bfloat16)def gmm(a, b, batch_sizes, trans_b=False):
batch_sizes = batch_sizes.numpy()out = [] start = 0 for i, size in enumerate(batch_sizes): rhs = b[i, :, :].t() if trans_b else b[i, :, :] out.append(a[start:start + size, :] @ rhs) start += size return torch.cat(out)
@parameterized.parameters(*_TEST_PROBLEMS)
class OpsTest(parameterized.TestCase):def testGroupedGemm_FixedSizes(self, z, m, k, n, trans_b): torch.manual_seed(0) device_id = 3 a = randn(z, m, k, device_id).view(-1, k) b = randn(z, n, k, device_id) if trans_b else randn(z, k, n, device_id) batch_sizes = torch.tensor([m] * z) a.requires_grad_(True) b.requires_grad_(True) print("a.device: ",a.device) a_ref = a.detach().clone().requires_grad_(True) b_ref = b.detach().clone().requires_grad_(True) out = ops.gmm(a, b, batch_sizes, trans_b) expected_out = gmm(a_ref, b_ref, batch_sizes, trans_b) self.assertTrue(allclose(out, expected_out)) # Check gradients. out.sum().backward() expected_out.sum().backward() self.assertTrue(allclose(a.grad, a_ref.grad)) self.assertTrue(allclose(b.grad, b_ref.grad)) def testGroupedGemm_VariableSizes(self, z, m, k, n, trans_b): torch.manual_seed(0) device_id = 3 a = randn(z, m, k, device_id).view(-1, k) b = randn(z, n, k, device_id) if trans_b else randn(z, k, n, device_id) dist = torch.rand(z, ) dist /= dist.sum() batch_sizes = (dist * m).to(torch.long) error = m * z - batch_sizes.sum() batch_sizes[-1] += error assert batch_sizes.sum() == (m * z) a.requires_grad_(True) b.requires_grad_(True) a_ref = a.detach().clone().requires_grad_(True) b_ref = b.detach().clone().requires_grad_(True) out = ops.gmm(a, b, batch_sizes, trans_b) expected_out = gmm(a_ref, b_ref, batch_sizes, trans_b) self.assertTrue(allclose(out, expected_out)) # Check gradients. out.sum().backward() expected_out.sum().backward() self.assertTrue(allclose(a.grad, a_ref.grad)) self.assertTrue(allclose(b.grad, b_ref.grad))
if name == ‘main’:
def check_device(device_id):
try:
device = torch.device(f"cuda:{device_id}“)
tensor = torch.randn(3, 3, device=device)
print(f"Tensor created successfully on GPU {device_id}”)
except RuntimeError as e:
print(f"Error on GPU {device_id}: {e}")for i in range(torch.cuda.device_count()): check_device(i) if torch.cuda.is_available(): print("GPU 3 memory summary:") print(torch.cuda.memory_summary(device='cuda:3')) unittest.main()
