The ibutils-1.5.7.1-0.11.g616bc1e.x86_64.rpm from MLNX_OFED 2.4.1 requires libopensm.so.8()(64bit), but I failed to find opensm-libs that provides this version of libopensm.so.8.
Could someone points to location where I can download that rpm?
opensm-libs is located in the Mellanox OFED iso file under the RPMS directory. Regardless, I’d drop ibutilis-1.x and use ibutilis2 has it has better visibility and debugging capabilities to the Mellanox hardware and software.
