Hi @ShaneCCC
You must remember the case I asked about simulating two virtual channels as two MIPI sensors to output from NVARGUS as two video devices. Thanks for the help then. Now I met some issue in continuous works based on that solution.
I wrote a application to let the VC1 continuously output frames of different positions in FULL FOV frames of VC0 up on face detection result. Actually this is like the smart conference. But I found sometimes frame of VC1 output from argus got vertical lines… and the postions of lines are not fixed. please see picture I attached for details.
Do you have any idea about the reason of the lines?
Please check if any error message in argus-daemon log.
journalctl -u nvargus-daemon -f
Hi @ShaneCCC
I got below log with your command:
orin@orin-desktop:~$ journalctl -u nvargus-daemon -f
6月 08 16:22:45 orin-desktop nvargus-daemon[6735]: === demo2[8713]: CameraProvider destroyed (0xffff946ea370)=== demo2[8713]: WARNING: Cleaning up 1 outstanding queues…=== demo2[8713]: NOTE: Destroy all libargus objects before destroying the CameraProvider to avoid these warnings.=== demo2[8713]: Connection closed (FFFF9C4F5900)=== demo2[8713]: Connection cleaned up (FFFF9C4F5900)=== demo2[21783]: Connection established (FFFF9C4F5900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
6月 08 16:22:45 orin-desktop nvargus-daemon[6735]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
6月 08 16:22:45 orin-desktop nvargus-daemon[6735]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
6月 08 16:22:45 orin-desktop nvargus-daemon[6735]: NvPclHwGetModuleList: No module data found
6月 08 16:22:45 orin-desktop nvargus-daemon[6735]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
6月 08 16:22:45 orin-desktop nvargus-daemon[6735]: ---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
6月 08 16:22:45 orin-desktop nvargus-daemon[6735]: CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
6月 08 16:22:45 orin-desktop nvargus-daemon[6735]: === demo2[21783]: CameraProvider initialized (0xffff946d4300)CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
Looks like don’t have any error from the daemon log.
Maybe check the trace log.
@ShaneCCC
Thanks, what do you mean about trace log?
Enable the trace log by below command.
sudo su
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 3 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
Get the log by below command.
sudo su
cat /sys/kernel/debug/tracing/trace 2>&1 | tee t.txt
t.zip (2.3 MB)Hi @ShaneCCC
I captured the trace when issue appears as attached for you reference, thanks.!
Hi @ShaneCCC
Thanks for the help. I found the reason , shall be raw data has issue when I continuously change the positions of VC1 frames in full FOV.
