The image2d of orin drive not support color gamut conversion?
Software Version
DRIVE OS 6.0.8.1
Target Operating System
Linux
Hardware Platform
Host Machine Version
Hi, we are testing the image2d of orin drive for image format conversion, but we found that it does not seem to support converting images in yuv422-yuyv format to the four color gamuts (NvSciColorStd_REC601_SR/NvSciColorStd_REC601-ER/NvSciColorStd_REC709-SR/NvSciColorStd_REC709-ER) of RGBA format. Every time we set the conversion to these four color gamut RGBA formats, the NvMedia2DRegisterNvSciBufObj interface will report an error, The interface reported an error and returned a value of 1, and at this time,/var/log/syslog displays as follows:
Mar  6 07:54:19 tegra-ubuntu bash[666]: message repeated 2 times: [ Saving time to disk]
Mar  6 07:54:28 tegra-ubuntu bash[1550]: tail: /var/log/syslog: file truncated
Mar  6 07:54:29 tegra-ubuntu bash[666]: Saving time to disk
Mar  6 07:54:31 tegra-ubuntu gaImg2dTest: [73448465729] Module_id 50 Severity 2 : failed to determine color format from buffer image attrs, color format/standard combination not supported
Mar  6 07:54:31 tegra-ubuntu gaImg2dTest: [73448471389] Module_id 50 Severity 2 : failed to convert buffer to surface container, determining color format from buffer image attrs failed
Mar  6 07:54:31 tegra-ubuntu gaImg2dTest: [73448471672] Module_id 50 Severity 2 : failed to register buffer, converting buffer to surface container failed
Mar  6 07:54:31 tegra-ubuntu gaImg2dTest: [73448471871] Module_id 50 Severity 2 : failed to register buffer
Mar  6 07:54:31 tegra-ubuntu gaImg2dTest: [73448472023] Module_id 50 Severity 2 : failed to register buffer with NvMedia2D
Does image2d not support the conversion of these four color gamuts? What is the difference between NvSciColorStd_SRGB and NvSciColorStd_REC709-ER/NvSciColorStd_REC709-SR? What is the difference between NvSciColorStd_REC709-ER and NvSciColorStd_REC709-SR color gamut?
Also, after being output by ISP, is the RAW camera a REC709 full range?
Dear @TomFord,
Could you share the cfg file?
Dear @SivaRamaKrishnaNV
We don’t have a cfg file, we directly set parameters to call the interface. As shown below:
Dear @TomFord,
The used color format, colorstd is not supported
In industry terms, SR = Limited Range and ER = Full Range . Please see 709 and 709 full range - Avid Community if it helps.
ISP output has limitations on color space. For ISP0 and ISP1 output, it supports only REC_709_ER
