1.JetPack on Jetson-TX2 is 3.2,JetPack on Jetson-xavier is 4.2.
2.when connect the camera:
nvidia@nvidia:~$ lsusb
Bus 002 Device 002: ID 05e3:0612 Genesys Logic, Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 199e:8302 The Imaging Source Europe GmbH
Bus 001 Device 005: ID 17ef:6099 Lenovo
Bus 001 Device 004: ID 17ef:608d Lenovo
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
nvidia@nvidia:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2988) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:30:11 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2b000000
[ 0.000000] OF: fdt: - ab200000 , 3da00000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a0697000
[ 0.000000] Found lut_mem: 00002008@a0693000
[ 0.000000] Found vpr, start=0xf0000000 size=8000000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000e4800000
[ 0.000000] On node 0 totalpages: 4095997
[ 0.000000] DMA zone: 6656 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 425981 pages, LIFO batch:31
[ 0.000000] Normal zone: 57344 pages used for memmap
[ 0.000000] Normal zone: 3670016 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc3ffda5000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4031997
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0697000 lut_mem=0x2008@0xa0693000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29232(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 15994800K/16383988K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 323652K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000033] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009007] Console: colour dummy device 80x25
[ 0.012168] console [tty0] enabled
[ 0.015646] bootconsole [tegra_comb_uart0] disabled
[ 0.020783] kmemleak: Kernel memory leak detector disabled
[ 0.020852] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.020927] pid_max: default: 32768 minimum: 301
[ 0.022352] Security Framework initialized
[ 0.023141] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.023221] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.025616] ftrace: allocating 46802 entries in 183 pages
[ 0.466679] sched-energy: Sched-energy-costs installed from DT
[ 0.466924] ASID allocator initialised with 65536 entries
[ 0.510938] tegra-id: chipid=21917.
[ 0.510977] tegra-id: opt_subrevision=0.
[ 0.511080] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.511145] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.511262] DTB Build time: Mar 13 2019 00:34:33
[ 0.558855] CPU1: Booted secondary processor [4e0f0040]
[ 0.590881] CPU2: Booted secondary processor [4e0f0040]
[ 0.623255] CPU3: Booted secondary processor [4e0f0040]
[ 0.655368] CPU4: Booted secondary processor [4e0f0040]
[ 0.687706] CPU5: Booted secondary processor [4e0f0040]
[ 0.719876] CPU6: Booted secondary processor [4e0f0040]
[ 0.755959] CPU7: Booted secondary processor [4e0f0040]
[ 0.756926] Brought up 8 CPUs
[ 0.757638] SMP: Total of 8 processors activated.
[ 0.757704] CPU features: detected feature: Privileged Access Never
[ 0.757765] CPU features: detected feature: LSE atomic instructions
[ 0.757825] CPU features: detected feature: User Access Override
[ 0.757883] CPU features: detected feature: 32-bit EL0 Support
[ 0.764159] CPU: All CPU(s) started at EL2
[ 0.764316] alternatives: patching kernel code
[ 0.778943] devtmpfs: initialized
[ 0.863697] Initilizing CustomIPI irq domain
[ 0.864168] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.864269] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.866502] pinctrl core: initialized pinctrl subsystem
[ 0.866786] OS set in device tree is not L4T.
[ 0.867247] regulator-dummy: no parameters
[ 0.867604] Initializing plugin-manager
[ 0.867701] Plugin module not found
[ 0.867771] Plugin-manager status disabled
[ 0.869642] NET: Registered protocol family 16
[ 0.871689] pstore: using zlib compression
[ 0.873198] console [pstore-1] enabled
[ 0.873245] pstore: Registered ramoops as persistent store backend
[ 0.873305] ramoops: attached 0x200000@0xe8a00000, ecc: 0/0
[ 0.889210] cpuidle: using governor menu
[ 0.890866] bpmp: waiting for handshake
[ 0.890922] bpmp: handshake completed
[ 0.890992] bpmp: synchronizing channels
[ 0.891041] bpmp: channels synchronized
[ 0.891088] bpmp: mail init ok
[ 0.895745] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.896133] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.896209] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.896268] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.896328] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.896386] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.896447] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.896542] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.896669] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.896738] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.896804] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.902201] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.902756] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.907464] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.909352] Registering BPMP clocks…
[ 0.909599] tegra_bpmp_clk_init: clock init ok (395 clks)
[ 0.910215] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.910833] tegra_powergate_init: DONE
[ 0.911038] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.911241] DTB Build time: Mar 13 2019 00:34:33
[ 0.915760] Tegra reboot handler registered.
[ 0.927831] iommu: Adding device 14180000.pcie to group 0
[ 0.928974] iommu: Adding device 14100000.pcie to group 1
[ 0.930244] iommu: Adding device 14140000.pcie to group 2
[ 0.931439] iommu: Adding device 141a0000.pcie to group 3
[ 0.933906] iommu: Adding device 2490000.ether_qos to group 4
[ 0.934744] iommu: Adding device 3100000.serial to group 5
[ 0.935589] iommu: Adding device 3110000.serial to group 6
[ 0.936235] iommu: Adding device 3140000.serial to group 7
[ 0.937086] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.937412] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.937507] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.937604] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.937660] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.937765] tegra-pmc: PMC Prod config success
[ 0.938082] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.938178] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.938788] iommu: Adding device 3460000.sdhci to group 8
[ 0.939628] iommu: Adding device 3400000.sdhci to group 9
[ 0.940439] iommu: Adding device 2450000.ufshci to group 10
[ 0.941252] iommu: Adding device c260000.spi to group 11
[ 0.942452] iommu: Adding device 3160000.i2c to group 12
[ 0.943059] iommu: Adding device c240000.i2c to group 13
[ 0.943742] iommu: Adding device 3180000.i2c to group 14
[ 0.944350] iommu: Adding device 3190000.i2c to group 15
[ 0.945110] iommu: Adding device 31b0000.i2c to group 16
[ 0.945749] iommu: Adding device 31c0000.i2c to group 17
[ 0.946361] iommu: Adding device c250000.i2c to group 18
[ 0.947010] iommu: Adding device 31e0000.i2c to group 19
[ 0.948164] iommu: Adding device sound to group 20
[ 0.948973] iommu: Adding device 3510000.hda to group 21
[ 0.949823] iommu: Adding device bc00000.rtcpu to group 22
[ 0.953053] iommu: Adding device 13e10000.host1x to group 23
[ 0.953692] iommu: Adding device 13e10000.host1x:ctx0 to group 24
[ 0.954341] iommu: Adding device 13e10000.host1x:ctx1 to group 25
[ 0.954917] iommu: Adding device 13e10000.host1x:ctx2 to group 26
[ 0.955512] iommu: Adding device 13e10000.host1x:ctx3 to group 27
[ 0.956112] iommu: Adding device 13e10000.host1x:ctx4 to group 28
[ 0.956699] iommu: Adding device 13e10000.host1x:ctx5 to group 29
[ 0.957273] iommu: Adding device 13e10000.host1x:ctx6 to group 30
[ 0.957985] iommu: Adding device 13e10000.host1x:ctx7 to group 31
[ 0.958872] iommu: Adding device 15340000.vic to group 32
[ 0.959506] iommu: Adding device 15380000.nvjpg to group 33
[ 0.959954] iommu: Adding device 15500000.tsec to group 34
[ 0.960397] iommu: Adding device 15100000.tsecb to group 35
[ 0.960844] iommu: Adding device 15480000.nvdec to group 36
[ 0.961293] iommu: Adding device 15140000.nvdec1 to group 37
[ 0.961957] iommu: Adding device 154c0000.nvenc to group 38
[ 0.962407] iommu: Adding device 15a80000.nvenc1 to group 39
[ 0.963050] iommu: Adding device 15880000.nvdla0 to group 40
[ 0.963672] iommu: Adding device 158c0000.nvdla1 to group 41
[ 0.964533] iommu: Adding device 15200000.nvdisplay to group 42
[ 0.964984] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0697000(800000)
[ 0.965073] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0693000(3000)
[ 0.966378] platform 15200000.nvdisplay: IOVA linear map 0x00000000f0000000(8000000)
[ 0.966457] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.967224] iommu: Adding device 15210000.nvdisplay to group 43
[ 0.967362] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.968008] iommu: Adding device 15220000.nvdisplay to group 44
[ 0.968154] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.971073] iommu: Adding device 15c10000.vi to group 45
[ 0.971413] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.971988] iommu: Adding device 14800000.isp to group 46
[ 0.974037] iommu: Adding device 16000000.pva0 to group 47
[ 0.974925] iommu: Adding device 16800000.pva1 to group 48
[ 0.975546] iommu: Adding device 15810000.se to group 49
[ 0.976167] iommu: Adding device 15820000.se to group 50
[ 0.976634] iommu: Adding device 15830000.se to group 51
[ 0.977076] iommu: Adding device 15840000.se to group 52
[ 0.977539] iommu: Adding device c1a0000.aon to group 53
[ 0.979856] iommu: Adding device d000000.bpmp to group 54
[ 0.980346] bpmp: ping status is 0
[ 0.980542] bpmp d000000.bpmp: firmware tag is 1c1b2165fe52a0a54ad7caf60d40cdc3
[ 0.984504] bpmp d000000.bpmp: probe ok
[ 0.986784] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 0.987591] iommu: Adding device smmu_test to group 55
[ 0.989032] mc: mapped MMIO address: 0xffffff800a560000 → 0x2c10000
[ 0.989126] mc: mapped MMIO address: 0xffffff800a580000 → 0x2c20000
[ 0.989213] mc: mapped MMIO address: 0xffffff800a5a0000 → 0x2c30000
[ 0.989295] mc: mapped MMIO address: 0xffffff800a5c0000 → 0x2c40000
[ 0.989377] mc: mapped MMIO address: 0xffffff800a5e0000 → 0x2c50000
[ 0.989459] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2b80000
[ 0.989540] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2b90000
[ 0.989635] mc: mapped MMIO address: 0xffffff800b010000 → 0x2ba0000
[ 0.989718] mc: mapped MMIO address: 0xffffff800b030000 → 0x2bb0000
[ 0.989799] mc: mapped MMIO address: 0xffffff800b050000 → 0x1700000
[ 0.989881] mc: mapped MMIO address: 0xffffff800b070000 → 0x1710000
[ 0.989961] mc: mapped MMIO address: 0xffffff800b090000 → 0x1720000
[ 0.990047] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1730000
[ 0.990137] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1740000
[ 0.990223] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1750000
[ 0.990304] mc: mapped MMIO address: 0xffffff800b110000 → 0x1760000
[ 0.990389] mc: mapped MMIO address: 0xffffff800b130000 → 0x1770000
[ 0.990544] mc-err: mcerr ops are set to t19x
[ 0.999275] iommu: Adding device 2600000.dma to group 56
[ 1.007097] GPIO line 490 (pcie-reg-enable) hogged as output/high
[ 1.007194] GPIO line 289 (pcie-reg-enable) hogged as output/high
[ 1.007290] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.007913] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.017435] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 1.017943] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.020998] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.021068] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.022229] iommu: Adding device 3550000.xudc to group 57
[ 1.023394] iommu: Adding device 3610000.xhci to group 58
[ 1.026779] arm64_ras arm64_ras: probed
[ 1.027416] ras_fhi_enable: FHI 477 enabled on CPU0
[ 1.027560] ras_fhi_enable: FHI 478 enabled on CPU1
[ 1.027713] ras_fhi_enable: FHI 479 enabled on CPU2
[ 1.027864] ras_fhi_enable: FHI 480 enabled on CPU3
[ 1.028031] ras_fhi_enable: FHI 481 enabled on CPU4
[ 1.028176] ras_fhi_enable: FHI 482 enabled on CPU5
[ 1.028267] ras_fhi_enable: FHI 483 enabled on CPU6
[ 1.028369] ras_fhi_enable: FHI 484 enabled on CPU7
[ 1.028727] carmel_ras_enable: RAS enabled on cpu0
[ 1.029097] carmel_ras_enable: RAS enabled on cpu1
[ 1.029485] carmel_ras_enable: RAS enabled on cpu2
[ 1.029778] carmel_ras_enable: RAS enabled on cpu3
[ 1.030124] carmel_ras_enable: RAS enabled on cpu4
[ 1.030417] carmel_ras_enable: RAS enabled on cpu5
[ 1.030709] carmel_ras_enable: RAS enabled on cpu6
[ 1.030984] carmel_ras_enable: RAS enabled on cpu7
[ 1.031155] carmel_ras carmel_ras: probed
[ 1.032995] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 1.033819] tegra-cbb c600000.aon-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[ 1.035049] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
[ 1.036353] tegra-cbb be00000.rce-noc: noc_secure_irq = 492, noc_nonsecure_irq = 491>
[ 1.037603] tegra-cbb b600000.sce-noc: noc_secure_irq = 494, noc_nonsecure_irq = 493>
[ 1.038155] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.041382] vdd-3v3-cvb: 3300 mV
[ 1.041840] vdd-1v8-cvb: 1800 mV
[ 1.042368] vdd-1v8-sd: 1800 mV
[ 1.042949] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.043038] vdd-epb-1v0: 1000 mV
[ 1.043535] vdd-sdmmc1-sw: 3300 mV
[ 1.044051] avdd-cam-2v8: 2800 mV
[ 1.044436] vdd-sata-1v5: 1500 mV
[ 1.044864] vdd-1v8-slt: 1800 mV
[ 1.045303] vdd-3v3-slt: 3300 mV
[ 1.045752] vdd-fan: 5000 mV
[ 1.046222] vdd-hdmi-5v0: 5000 mV
[ 1.046711] vdd_sys_en: 1200 mV
[ 1.047311] vdd-5v-sata: 5000 mV
[ 1.047807] vdd-ac-bat: 5000 mV
[ 1.048087] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.086440] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.092277] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.092762] SCSI subsystem initialized
[ 1.093235] libata version 3.00 loaded.
[ 1.093524] usbcore: registered new interface driver usbfs
[ 1.093661] usbcore: registered new interface driver hub
[ 1.093861] usbcore: registered new device driver usb
[ 1.107971] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.111065] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.122135] vdd-1v0: at 1000 mV
[ 1.126033] vdd-1v8-hs: at 1800 mV
[ 1.129977] vdd-1v8-ls: at 1800 mV
[ 1.133968] vdd-1v8-ao: at 1800 mV
[ 1.142012] vddio-ddr-1v1: at 1100 mV
[ 1.148195] vdd-rtc: at 800 mV
[ 1.149725] spmic-ldo1: at 2375 mV
[ 1.158605] vdd-ao-3v3: at 3300 mV
[ 1.168341] vddio-emmc-3v3: at 3300 mV
[ 1.170195] spmic-ldo4: at 1587 mV
[ 1.176416] vdd-usb-3v3: at 3300 mV
[ 1.184516] vddio-sdmmc1-3v3: at 3300 mV
[ 1.188537] vdd-csi-1v2: at 1200 mV
[ 1.190272] spmic-ldo8: at 1800 mV
[ 1.192744] GPIO line 246 (gpio_default) hogged as output/high
[ 1.194309] GPIO line 247 (gpio_default) hogged as output/high
[ 1.195011] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.198900] max77620 4-003c: max77620 probe successful
[ 1.199677] media: Linux media interface: v0.10
[ 1.199841] Linux video capture interface: v2.00
[ 1.201637] pps_core: LinuxPPS API ver. 1 registered
[ 1.201708] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.201853] PTP clock support registered
[ 1.202746] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.202854] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.204530] tegra_fiq_debugger_init: found FIQ source (IRQ 469)
[ 1.206559] Advanced Linux Sound Architecture Driver Initialized.
[ 1.207339] Bluetooth: Core ver 2.22
[ 1.207440] NET: Registered protocol family 31
[ 1.207531] Bluetooth: HCI device and connection manager initialized
[ 1.207613] Bluetooth: HCI socket layer initialized
[ 1.207682] Bluetooth: L2CAP socket layer initialized
[ 1.207783] Bluetooth: SCO socket layer initialized
[ 1.211031] camchar: rtcpu character device driver loaded
[ 1.212828] clocksource: Switched to clocksource arch_sys_counter
[ 1.273766] VFS: Disk quotas dquot_6.6.0
[ 1.273977] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.274506] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.276733] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.276941] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000f0000000,134217728
[ 1.277051] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.277106] nvmap_page_pool_init: Total RAM pages: 4015084
[ 1.277139] nvmap_page_pool_init: nvmap page pool size: 501885 pages (1960 MB)
[ 1.277440] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.278271] misc nvmap: created heap vpr base 0x00000000f0000000 size (131072KiB)
[ 1.280340] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.297750] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.298234] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.298654] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.299041] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.299650] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.300112] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.300354] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.301935] la/ptsa driver initialized.
[ 1.302438] NET: Registered protocol family 2
[ 1.303542] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.304300] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.305286] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.305401] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.305747] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.306496] NET: Registered protocol family 1
[ 1.307494] RPC: Registered named UNIX socket transport module.
[ 1.307571] RPC: Registered udp transport module.
[ 1.307658] RPC: Registered tcp transport module.
[ 1.307708] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.307773] PCI: CLS 0 bytes, default 64
[ 1.308088] Trying to unpack rootfs image as initramfs…
[ 1.333002] random: fast init done
[ 1.338731] host1x 13e10000.host1x: initialized
[ 1.342144] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.348442] audit: initializing netlink subsys (disabled)
[ 1.348578] audit: type=2000 audit(0.916:1): initialized
[ 1.349894] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.365266] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.367284] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.368284] 9p: Installing v9fs 9p2000 file system support
[ 1.376648] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.376952] io scheduler noop registered
[ 1.377308] io scheduler cfq registered (default)
[ 1.382125] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.423959] iommu: Adding device 2993000.adsp to group 59
[ 1.529845] iommu: Adding device aconnect@2a41000:adsp_audio to group 60
[ 1.530892] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.547888] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.548633] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.549282] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.552912] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.553320] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.553388] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.557726] tsec 15500000.tsec: initialized
[ 1.560196] tsec 15100000.tsecb: initialized
[ 1.566011] nvdec 15480000.nvdec: initialized
[ 1.569738] nvdec 15140000.nvdec1: initialized
[ 1.577201] falcon 15340000.vic: initialized
[ 1.579479] falcon 15380000.nvjpg: initialized
[ 1.581812] falcon 154c0000.nvenc: initialized
[ 1.584532] falcon 15a80000.nvenc1: initialized
[ 1.589405] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.593311] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.596399] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.598768] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.601085] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.603269] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.605532] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.607895] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.612961] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.619602] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.620140] scare-pigeon 14b00000.isp-thi: initialized
[ 1.631015] pva 16000000.pva0: initialized
[ 1.663967] pva 16800000.pva1: initialized
[ 1.695769] nvdla 15880000.nvdla0: initialized
[ 1.727226] nvdla 158c0000.nvdla1: initialized
[ 1.731626] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 1.731896] tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
[ 1.731945] tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
[ 1.731999] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 1.733498] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.733566] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.733669] tegradccommon 15200000.dc_common: dma mapping done
[ 1.734982] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.735203] generic_infoframe_type: 0x87
[ 1.735442] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.735547] tegradc 15200000.nvdisplay: Display dc.ffffff800bd90000 registered with id=0
[ 1.743615] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.743700] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.743739] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.744081] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.744126] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.746101] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.746855] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.748891] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.749629] kfuse 3830000.kfuse: initialized
[ 1.750478] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.750547] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.756945] tegradc 15200000.nvdisplay: probed
[ 1.759030] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.762738] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.764335] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.765523] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 4.247475] console [ttyTCU0] enabled
[ 4.248064] [drm] Initialized
[ 4.248155] Console: switching to colour frame buffer device 240x67
[ 4.260350] tegradc 15200000.nvdisplay: fb registered
[ 4.265986] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.270826] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.275408] brd: module loaded
[ 4.279178] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.283579] loop: module loaded
[ 4.283707] tegra_profiler: version: 1.132, samples/io: 46/26
[ 4.283855] tegra_profiler: auth: init
[ 4.284452] nct1008_nct72 4-004c: starting parse dt
[ 4.284583] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 4.284590] nct1008_nct72 4-004c: success parsing dt
[ 4.284909] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 4.285245] THERMAL EST: found 3 subdevs
[ 4.285250] THERMAL EST num_resources: 0
[ 4.285253] [THERMAL EST subdev 0]
[ 4.285258] [THERMAL EST subdev 1]
[ 4.285262] [THERMAL EST subdev 2]
[ 4.285742] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.285745] THERMAL EST: thz register success.
[ 4.285942] THERMAL EST: end of probe, return err: 0
[ 4.287049] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 4.287060] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.288534] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 459
[ 4.288544] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[ 4.319999] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 4.334510] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 4.396638] nct1008_nct72 4-004c: initial LOC temp: 23000
[ 4.406291] nct1008_nct72 4-004c: initial EXT temp: 35000
[ 4.410389] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 4.411696] Parent Clock set for DC plld3
[ 4.417851] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 4.418631] scsi host0: ufshcd
[ 4.429761] hisi_sas: driver version v1.6
[ 4.437223] libphy: Fixed MDIO Bus: probed
[ 4.438134] tun: Universal TUN/TAP device driver, 1.6
[ 4.439139] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 4.446495] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.451056] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.456929] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.463886] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.468456] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 4.469251] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 4.469266] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 4.469885] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.469888] Extcon AUX2(HDMI) enable
[ 4.470548] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 4.471022] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 4.518838] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.526231] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.532291] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.539357] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.546375] eqos 2490000.ether_qos: no PHY interrupt found
[ 4.554651] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb 95 b0
[ 4.556244] libphy: dwc_phy: probed
[ 4.564247] PPP generic driver version 2.4.2
[ 4.564669] PPP BSD Compression module registered
[ 4.568939] PPP Deflate Compression module registered
[ 4.573905] PPP MPPE Compression module registered
[ 4.579128] NET: Registered protocol family 24
[ 4.583439] usbcore: registered new interface driver r8152
[ 4.589186] usbcore: registered new interface driver asix
[ 4.594444] usbcore: registered new interface driver ax88179_178a
[ 4.600889] usbcore: registered new interface driver cdc_ether
[ 4.606825] usbcore: registered new interface driver net1080
[ 4.606839] tegradc 15200000.nvdisplay: blank - powerdown
[ 4.606877] usbcore: registered new interface driver cdc_subset
[ 4.606967] usbcore: registered new interface driver zaurus
[ 4.607020] usbcore: registered new interface driver cdc_ncm
[ 4.607388] VFIO - User Level meta-driver version: 0.3
[ 4.609161] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.609181] ehci-pci: EHCI PCI platform driver
[ 4.609227] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.609237] ohci-pci: OHCI PCI platform driver
[ 4.609277] ohci-platform: OHCI generic platform driver
[ 4.618472] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.618478] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 4.621446] Could not get extcon-dev /xhci@3610000:id(0)
[ 4.625073] usbcore: registered new interface driver uas
[ 4.625177] usbcore: registered new interface driver usb-storage
[ 4.625376] usbcore: registered new interface driver usbserial
[ 4.630048] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.630117] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 4.633390] ucsi_ccg 1-0008: FW1 Version: gn v12.05, [Base 3.1.2.1487]
[ 4.633400] ucsi_ccg 1-0008: FW2 Version: gn v12.05, [Base 3.1.2.1487]
[ 4.634518] ucsi_ccg 1-0008: fw_mode: 2
[ 4.634523] ucsi_ccg 1-0008: fw1_invalid: 0
[ 4.634528] ucsi_ccg 1-0008: fw2_invalid: 0
[ 4.634533] ucsi_ccg 1-0008: silicon_id: 0x1f00
[ 4.634752] ucsi_ccg 1-0008: typec-port0 extcon dev created
[ 4.634929] ucsi_ccg 1-0008: typec-port1 extcon dev created
[ 4.635079] ucsi_ccg 1-0008: typec-pd extcon dev created
[ 4.635360] gpio tegra-gpio-aon wake48 for gpio=10(BB:2)
[ 4.636978] ucsi_ccg 1-0008: dev event code: 0x80, data len: 0
[ 4.638397] ucsi_ccg 1-0008: CCG reset complete
[ 4.641182] ucsi_ccg 1-0008: FW1 Version: gn v12.05, [Base 3.1.2.1487]
[ 4.641192] ucsi_ccg 1-0008: FW2 Version: gn v12.05, [Base 3.1.2.1487]
[ 4.643498] ucsi_ccg 1-0008: fw_mode: 2
[ 4.643504] ucsi_ccg 1-0008: fw1_invalid: 0
[ 4.643508] ucsi_ccg 1-0008: fw2_invalid: 0
[ 4.643514] ucsi_ccg 1-0008: silicon_id: 0x1f00
[ 4.643519] ucsi_ccg 1-0008: Reset Complete.
[ 4.647578] ucsi_ccg 1-0008: HPI Command Success.
[ 4.651037] ucsi_ccg 1-0008: HPI Command Success.
[ 4.651059] ucsi_ccg 1-0008: ucsi_ccg_init: complete
[ 4.652096] mousedev: PS/2 mouse device common for all mice
[ 4.652182] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 4.652216] Extcon AUX2(HDMI) disable
[ 4.652232] usbcore: registered new interface driver xpad
[ 4.679085] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 4.680456] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 4.711582] tegradc 15200000.nvdisplay: unblank
[ 4.713737] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.714076] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.731436] Parent Clock set for DC plld3
[ 4.736743] tegradc 15200000.nvdisplay: hdmi: tmds rate:138500K prod-setting:prod_c_hdmi_111m_223m
[ 4.738410] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 4.738458] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4.742573] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.742576] Extcon AUX2(HDMI) enable
[ 4.791623] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.793670] Wake73 for irq=42
[ 4.795085] rtc rtc1: alarm rtc device
[ 4.795133] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.795164] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.795363] i2c /dev entries driver
[ 4.799116] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 4.804703] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.805159] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 2 not supported
[ 4.808476] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[ 4.863726] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[ 4.863803] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 4.863811] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 4.864135] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[ 4.864224] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 4.864232] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 4.864715] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[ 4.864899] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 4.864907] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 4.865394] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[ 4.865507] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 4.865557] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 4.865993] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 4.866064] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 4.866071] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 4.866471] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[ 4.867360] FAN dev name: pwm-fan
[ 4.867469] FAN:gpio request success.
[ 4.867477] FAN: can’t find tach_gpio
[ 4.867514] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 4.867877] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 4.867883] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.868272] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.868279] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[ 4.868285] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.868291] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.868297] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.868303] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.868308] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.868346] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.868353] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.868360] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.869664] device-mapper: uevent: version 1.0.3
[ 4.870423] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.874425] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 4.876264] cpuidle: Initializing cpuidle driver
[ 4.877403] sdhci: Secure Digital Host Controller Interface driver
[ 4.877404] sdhci: Copyright(c) Pierre Ossman
[ 4.877405] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.878920] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.881044] CMDQ: cmdq_platfm_init successful
[ 4.881483] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.882919] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.884403] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 254
[ 4.888559] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.890209] tegra-se-nvhost 15810000.se: initialized
[ 4.891556] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.892350] tegra-se-nvhost 15820000.se: initialized
[ 4.893367] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.894142] tegra-se-nvhost 15830000.se: initialized
[ 4.894750] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.895468] tegra-se-nvhost 15840000.se: initialized
[ 4.896273] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.896493] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.897712] usbcore: registered new interface driver usbhid
[ 4.897713] usbhid: USB HID core driver
[ 4.903001] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 4.904009] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.904411] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.904965] denver_knobs_init:MTS_VERSION:44201972
[ 4.905169] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 4.905857] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.906223] t19x_cache tegra-cache: probed
[ 4.912555] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 4.912564] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 4.914929] nvpmodel: initialized successfully
[ 4.915969] tegra-hda 3510000.hda: Override SDO lines to 4
[ 4.916147] usbcore: registered new interface driver snd-usb-audio
[ 4.924844] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.928983] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 4.929042] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.935488] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.935667] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.935845] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 4.936048] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 5.006665] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 5.019156] mmc0: periodic cache flush enabled
[ 5.019187] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.019706] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 5.019987] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 5.020180] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 5.020339] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[ 5.023232] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36 p37
[ 6.969267] gpio tegra-gpio wake12 for gpio=149(S:5)
[ 7.605507] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 7.612944] Extcon HDMI: HPD enabled
[ 7.616676] tegradc 15200000.nvdisplay: hdmi: plugged
[ 7.696489] OPE platform probe
[ 7.697958] OPE platform probe successful
[ 7.833727] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 7.835216] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 7.836614] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 7.838018] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 7.839396] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 7.840750] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 7.842658] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 7.844642] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 7.846017] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 7.847358] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 7.848669] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 7.849989] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 7.851296] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 7.852581] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 7.853850] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 7.855106] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 7.856337] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 7.857572] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 7.858839] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 7.860038] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 7.899982] input: tegra-snd-t19x-mobile-rt565x Headset Jack as /devices/sound/sound/card1/input4
[ 7.902476] u32 classifier
[ 7.903551] Actions configured
[ 7.904697] Initializing XFRM netlink socket
[ 7.906349] NET: Registered protocol family 10
[ 7.908210] NET: Registered protocol family 17
[ 7.909313] NET: Registered protocol family 15
[ 7.910467] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 7.911869] Bluetooth: RFCOMM socket layer initialized
[ 7.913038] Bluetooth: RFCOMM ver 1.11
[ 7.915793] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 7.921783] Bluetooth: HIDP socket layer initialized
[ 7.926754] 9pnet: Installing 9P2000 support
[ 7.931169] Key type dns_resolver registered
[ 7.935813] Registered cp15_barrier emulation handler
[ 7.940667] Registered setend emulation handler
[ 7.946844] registered taskstats version 1
[ 7.949698] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 7.957294] OF: PCI: host bridge /pcie@14180000 ranges:
[ 7.961528] OF: PCI: IO 0x38100000…0x381fffff → 0x38100000
[ 7.967536] OF: PCI: MEM 0x38200000…0x39ffffff → 0x38200000
[ 7.973488] OF: PCI: MEM 0x1800000000…0x1bffffffff → 0x1800000000
[ 8.088851] tegra-pcie-dw 14180000.pcie: link is up
[ 8.090203] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 8.091323] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 8.092404] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 8.093573] pci_bus 0000:00: root bus resource [mem 0x38200000-0x39ffffff]
[ 8.094677] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1bffffffff pref]
[ 8.095779] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 8.095914] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 8.096158] iommu: Adding device 0000:00:00.0 to group 61
[ 8.097483] pci 0000:01:00.0: [8086:f1a6] type 00 class 0x010802
[ 8.097604] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 8.098540] iommu: Adding device 0000:01:00.0 to group 62
[ 8.110043] pci 0000:00:00.0: BAR 14: assigned [mem 0x38200000-0x382fffff]
[ 8.111160] pci 0000:01:00.0: BAR 0: assigned [mem 0x38200000-0x38203fff 64bit]
[ 8.112310] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 8.113401] pci 0000:00:00.0: bridge window [mem 0x38200000-0x382fffff]
[ 8.114488] pci 0000:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 8.115635] pci 0000:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 8.117027] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.118100] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 8.119185] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[ 8.119287] aer 0000:00:00.0:pcie002: service driver aer loaded
[ 8.119730] nvme nvme0: pci function 0000:01:00.0
[ 8.120855] nvme 0000:01:00.0: enabling device (0000 → 0002)
[ 8.121051] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 8.121801] OF: PCI: host bridge /pcie@14100000 ranges:
[ 8.121830] OF: PCI: IO 0x30100000…0x301fffff → 0x30100000
[ 8.121836] OF: PCI: MEM 0x30200000…0x31ffffff → 0x30200000
[ 8.121841] OF: PCI: MEM 0x1200000000…0x123fffffff → 0x1200000000
[ 8.228852] tegra-pcie-dw 14100000.pcie: link is up
[ 8.230076] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.231135] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.232147] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 8.233299] pci_bus 0001:00: root bus resource [mem 0x30200000-0x31ffffff]
[ 8.234387] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x123fffffff pref]
[ 8.235536] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 8.235669] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 8.235855] iommu: Adding device 0001:00:00.0 to group 63
[ 8.237272] pci 0001:01:00.0: [1b4b:9171] type 00 class 0x010601
[ 8.237379] pci 0001:01:00.0: reg 0x10: [io 0x8000-0x8007]
[ 8.237463] pci 0001:01:00.0: reg 0x14: [io 0x8040-0x8043]
[ 8.237523] pci 0001:01:00.0: reg 0x18: [io 0x8100-0x8107]
[ 8.237583] pci 0001:01:00.0: reg 0x1c: [io 0x8140-0x8143]
[ 8.237643] pci 0001:01:00.0: reg 0x20: [io 0x800000-0x80000f]
[ 8.237704] pci 0001:01:00.0: reg 0x24: [mem 0x00900000-0x009001ff]
[ 8.237764] pci 0001:01:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
[ 8.238090] pci 0001:01:00.0: PME# supported from D3hot
[ 8.238335] iommu: Adding device 0001:01:00.0 to group 64
[ 8.249586] pci 0001:00:00.0: BAR 14: assigned [mem 0x30200000-0x302fffff]
[ 8.250701] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 8.251804] pci 0001:01:00.0: BAR 6: assigned [mem 0x30200000-0x3020ffff pref]
[ 8.252962] pci 0001:01:00.0: BAR 5: assigned [mem 0x30210000-0x302101ff]
[ 8.254131] pci 0001:01:00.0: BAR 4: assigned [io 0x100000-0x10000f]
[ 8.255321] pci 0001:01:00.0: BAR 0: assigned [io 0x100010-0x100017]
[ 8.256492] pci 0001:01:00.0: BAR 2: assigned [io 0x100018-0x10001f]
[ 8.257783] pci 0001:01:00.0: BAR 1: assigned [io 0x100020-0x100023]
[ 8.258988] pci 0001:01:00.0: BAR 3: assigned [io 0x100024-0x100027]
[ 8.261074] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.266009] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 8.272513] pci 0001:00:00.0: bridge window [mem 0x30200000-0x302fffff]
[ 8.279226] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.287910] pci 0001:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 8.296707] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.303121] pci 0001:01:00.0: Signaling PME through PCIe PME interrupt
[ 8.309913] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
[ 8.310022] aer 0001:00:00.0:pcie002: service driver aer loaded
[ 8.310546] ahci 0001:01:00.0: version 3.0
[ 8.311067] ahci 0001:01:00.0: AHCI 0001.0000 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 8.317970] ahci 0001:01:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 8.326838] scsi host1: ahci
[ 8.328607] nvme0n1: p1
[ 8.328708] ata1: SATA max UDMA/133 abar m512@0x30210000 port 0x30210100 irq 595
[ 8.328965] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 8.329849] OF: PCI: host bridge /pcie@14140000 ranges:
[ 8.329881] OF: PCI: IO 0x34100000…0x341fffff → 0x34100000
[ 8.329888] OF: PCI: MEM 0x34200000…0x35ffffff → 0x34200000
[ 8.329891] OF: PCI: MEM 0x1280000000…0x12bfffffff → 0x1280000000
[ 8.656075] ata1: SATA link down (SStatus 0 SControl 300)
[ 8.838608] tegra-pcie-dw 14140000.pcie: link is down
[ 8.840008] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 8.841262] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 8.842445] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 8.843745] pci_bus 0003:00: root bus resource [mem 0x34200000-0x35ffffff]
[ 8.844955] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12bfffffff pref]
[ 8.846167] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 8.846318] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 8.846567] iommu: Adding device 0003:00:00.0 to group 65
[ 8.847994] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 8.849200] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.850647] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.851857] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
[ 8.851951] aer 0003:00:00.0:pcie002: service driver aer loaded
[ 8.852118] pcie_pme 0003:00:00.0:pcie001: unloading service driver pcie_pme
[ 8.852169] aer 0003:00:00.0:pcie002: unloading service driver aer
[ 8.852258] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[ 8.852339] iommu: Removing device 0003:00:00.0 from group 65
[ 8.853582] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[ 8.853830] tegra-pcie-dw 14140000.pcie: PCIe link is not up…!
[ 8.855594] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 8.857925] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 8.859118] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 8.860407] OF: PCI: MEM 0x3a200000…0x3bffffff → 0x3a200000
[ 8.861611] OF: PCI: MEM 0x1c00000000…0x1fffffffff → 0x1c00000000
[ 9.370951] tegra-pcie-dw 141a0000.pcie: link is down
[ 9.372360] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 9.373671] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 9.374851] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 9.376107] pci_bus 0005:00: root bus resource [mem 0x3a200000-0x3bffffff]
[ 9.377437] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1fffffffff pref]
[ 9.378769] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 9.379029] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 9.379208] iommu: Adding device 0005:00:00.0 to group 65
[ 9.380640] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 9.381870] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.383368] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 9.384572] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 9.384665] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 9.384888] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 9.384952] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 9.385029] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 9.385110] iommu: Removing device 0005:00:00.0 from group 65
[ 9.386333] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 9.386605] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
[ 9.400069] tegra-cbb 14040000.cv-noc: noc_secure_irq = 98, noc_nonsecure_irq = 97>
[ 9.406365] tegra194-isp5 14800000.isp: initialized
[ 9.415231] tegra194-vi5 15c10000.vi: initialized
[ 9.421754] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@0/endpoint.
[ 9.423781] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@1/endpoint.
[ 9.426625] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 9.428070] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 9.428547] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 9.428549] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 9.431592] tegra-xusb 3610000.xhci: extcon 0: ffffffc3eb06cc00 id
[ 9.432260] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 9.432298] tegra-xudc-new 3550000.xudc: device count: 1
[ 9.432392] tegra-xusb 3610000.xhci: Direct firmware load for tegra19x_xusb_firmware failed with error -2
[ 9.432411] tegra-xusb 3610000.xhci: Falling back to user helper
[ 9.433125] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 9.433129] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 9.433900] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 9.434080] tegra-xudc-new 3550000.xudc: entering ELPG
[ 9.434286] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 9.487323] tegradc 15210000.nvdisplay: DT parsed successfully
[ 9.493463] tegradc 15210000.nvdisplay: Display dc.ffffff800ff10000 registered with id=1
[ 9.501415] tegradc 15210000.nvdisplay: vblank syncpt # 15 for dc 1
[ 9.507519] tegradc 15210000.nvdisplay: vpulse3 syncpt # 16 for dc 1
[ 9.508982] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 9.509341] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 9.509525] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 9.509694] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 9.510020] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 9.510076] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 9.510250] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (69)
[ 9.510252] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 9.511280] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 9.511672] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 9.511731] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 9.511885] input: gpio-keys as /devices/gpio-keys/input/input5
[ 9.553277] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:16 UTC (946688416)
[ 9.553860] mmcblk mmc0:0001: Card claimed for testing.
[ 9.590959] bpmp: mounted debugfs mirror
[ 9.596352] vdd-1v8-cvb: disabling
[ 9.596355] vdd-1v8-sd: disabling
[ 9.596356] vdd-epb-1v0: disabling
[ 9.596358] avdd-cam-2v8: disabling
[ 9.596359] vdd-sata-1v5: disabling
[ 9.596360] vdd-3v3-slt: disabling
[ 9.596362] vdd-fan: disabling
[ 9.596363] vdd_sys_en: disabling
[ 9.596364] vdd-5v-sata: disabling
[ 9.596370] ALSA device list:
[ 9.596372] #0: tegra-hda-galen-t194 at 0x3518000 irq 68
[ 9.596373] #1: tegra-snd-t19x-mobile-rt565x
[ 9.687337] tegradc 15210000.nvdisplay: probed
[ 9.708509] tegradc 15210000.nvdisplay: fb registered
[ 9.713108] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 9.714381] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 9.715663] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 9.716949] tegradc 15210000.nvdisplay: blank - powerdown
[ 9.717221] tegradc 15220000.nvdisplay: disp2 connected to head2->/host1x/sor1
[ 9.717245] tegradc 15220000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 9.717332] tegradc 15220000.nvdisplay: DT parsed successfully
[ 9.717370] tegradc 15220000.nvdisplay: Display dc.ffffff80111d0000 registered with id=2
[ 9.717570] tegradc 15220000.nvdisplay: vblank syncpt # 17 for dc 2
[ 9.717573] tegradc 15220000.nvdisplay: vpulse3 syncpt # 18 for dc 2
[ 9.756325] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 9.764304] Extcon DP: HPD disabled
[ 9.767917] hpd: hpd_switch 0
[ 9.771078] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 9.778235] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 9.784104] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 9.792134] tegradc 15220000.nvdisplay: probed
[ 9.815372] tegradc 15220000.nvdisplay: fb registered
[ 9.820115] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 9.821515] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 9.822783] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 9.824039] tegradc 15220000.nvdisplay: blank - powerdown
[ 9.826643] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 9.834609] Extcon DP: HPD disabled
[ 9.838077] hpd: hpd_switch 0
[ 9.841491] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 9.848145] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 9.854108] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 9.861026] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.869016] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 9.878423] devtmpfs: mounted
[ 9.881411] Freeing unused kernel memory: 8512K
[ 9.979440] systemd[1]: System time before build time, advancing clock.
[ 10.001577] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.006362] cgroup: cgroup2: unknown option “nsdelegate”
[ 10.015601] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 10.019377] systemd[1]: Detected architecture arm64.
[ 10.033248] systemd[1]: Set hostname to .
[ 10.105259] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 10.107024] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 10.236191] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.238076] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.241412] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.242996] systemd[1]: Reached target User and Group Name Lookups.
[ 10.246436] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.248365] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.251870] systemd[1]: Reached target Swap.
[ 10.260146] systemd[1]: Created slice System Slice.
[ 10.320047] gpio tegra-gpio wake44 for gpio=192(Y:0)
[ 10.350608] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 10.370292] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 10.770380] systemd-journald[2402]: Received request to flush runtime journal from PID 1
[ 11.259473] tegra-xusb 3610000.xhci: cannot find firmware…retry after 1 second
[ 11.272114] bmi160 1-0069: nvs_vregs_init vdd err=-19
[ 11.272124] bmi160 1-0069: nvs_vregs_init vdd_IO err=-19
