The _imagingft C module is not installed
Hi!
I managed to install Luminoth (https://luminoth.readthedocs.io/en/latest/), respectively compile it using Python3 on Jetson AGX Xavier.
However, when I try to run it (using the
lumi checkpoint list
command), I get the following error:
ImportError: The _imagingft C module is not installed
which seems to be an error having to do with libfreetype6. The compiler somehow cannot find the library files.
Running
ln -sf /usr/lib/aarch64-linux-gnu/libfreetype.so.6 /usr/lib/
as sudo did not help.
Does anybody have a clue what is going on here?
Any help highly appreciated!
Lorenz
Update:
I just tried to recompile Pillow with
libfreetype
using
sudo pip3 install pillow --global-option="build_ext" --global-option="--enable-freetype" --global-option="--debug"
after cloning it from git.
However, this fails with the error
Couldn't find library freetype in ['/tmp/pip-install-z04i1y9l/pillow', '/usr/lib', '/usr/lib/aarch64-linux-gnu', '/lib/aarch64-linux-gnu', '/usr/lib/aarch64-linux-gnu/tegra', '/opt/nvidia/deepstream/deepstream-4.0/lib', '/usr/local/cuda-10.0/targets/aarch64-linux/lib', '/usr/local/lib', '/usr/lib/aarch64-linux-gnu/libfakeroot', '/usr/lib/aarch64-linux-gnu/tegra-egl', '/lib']
although I linked
libfreetype.so
and
libfreetype.so.6
to (some of) these directories. Reinstalling libfreetype via apt is no option, as it cannot locate the package dependencies.
Question is now, which of the files from the standard Jetson-libfreetype install directory (wherever it is…) do I need to link to
/usr/lib
Lorenz
Would you mind to try libfreetype6-dev?
$ sudo apt-get install libfreetype6-dev
This command unfortunately yields
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libfreetype6-dev : Depends: libpng-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
EDIT: Of course, I did
apt-get update
and
apt-get upgrade
as sudo before!
The error is related to libpng-dev. Have you tried to install libpng-dev first?
sudo apt-get install libpng-dev
May I know how do you set up your Xavier?
Both libpng-dev and libfreetype6-dev can be well installed in my environment.
