After running “/install_full.sh -m imx477,” the imx477 functionality indeed becomes available. However, the pin configuration I set in /opt/nvidia/jetson-io/jetson-io.py gets reset. Similarly, if I complete the configuration in /opt/nvidia/jetson-io/jetson-io.py and then reboot, all settings made by /install_full.sh -m imx477 disappear. How can this be addressed?
Hello @nancydada2000 and welcome to the NVIDIA developer forums!
Since this is a Jetson issue you might find better support in the actual Jetson forums. I recommend you check out this Knowledge-base Article and in case your issue does not get resolved, post in the applicable sub-category according to your board and add the information as requested in the above KB article.
