The installation of Jetpack with L4T R35.6.0
When I installed the Jetpack 5.1.4, I faced some problem. The error shows following:E: Unable to correct problems, you have held broken packages.
Please provide the full log for us to review.
Some questions to confirm
  • What is your flashing method? Through sdk manager or command line
When I plug in the power of Jetson Orin Nano today, the light in the Jetson Orin Nano is turning on. My display indicates that I need to change my input timing to 1920x1080,60Hz. However, the display resolution is 1920x1080,60Hz, which shows from my computer’s Settings. So now the Jetson Orin Nano can’t get acess to the login screen
Could you use minicom to access your device?
Happy New Year!
I just saw your reply after the vocation. I remembered that I had deleted all the files named Nvidia when I try to solve the dependency hell. Maybe that’s the reason why I can’t get access to the logging screen. Fortunately, I can use BIOS to access the device by tapping F11. Is that troublesome to fix the Ubuntu system directly through BIOS? Probably flashing is the easiest way to deal all the problems?
Yes, since your delete whole files named Nvidia, some important config might lose.
Thanks for your advice!
The system of my display is Windows. According to your official website:" SDK Manager | NVIDIA Developer", The Windows system is unsupported for using SDKmanager to Flashing. So now I probably need to change to the Linux system by installing Linux virtual machine or using a Linux system’s display?
Yes. You could use dual boot to install physical ubuntu.
OK
I 'll try to flash by dual boot.
Appreciate your help
