- Refer to " Headless Mode Flow in oem-config" of L4T guide, we can use a serial application to run oem-config.
- After flashing jetson device then starting up, we can find the output of “Please complete system configuration setup on the serial port provided by Jetson’s USB device mode connection. e.g. /dev/ttyACMx where x can 0, 1, 2 etc.”. And I connected jetson device to host computer with micro usb, found /dev/ttyACM0 on PC, but using putty or screen to open ttyACM0 fail.
- I know we can run oem-config by HDMI display, but i want to use a serial method, because i have no more HDMI display.
- I have also tried to use a 40‑pin header UART port to run oem-config, it fail too.
- My jetson device is Nano, and L4T version is 32.6.1.
What’s the issue about oem-config on serial method?
