The issue regarding Intel X710 ethernet controller
Hi NV團隊,請容我用我熟悉的語言來描述我們遇到的問題
附件是我們自定義載板的PCIe功能架構圖,在此架構的應用上,只有X710會 init fail,
error message如下,還請幫忙確認NV這邊是否能解決或提供幫助,如果還需要更詳盡的資料,我會盡力提供,謝謝您們!
[ 4.338798] i40e: Intel(R) Ethernet Connection XL710 Network Driver
[ 4.345806] i40e: Copyright (c) 2013 - 2019 Intel Corporation.
[ 17.484554] i40e 0005:01:00.0: Adding to iommu group 12
[ 17.490686] i40e 0005:01:00.0: enabling device (0000 → 0002)
[ 17.519432] i40e 0005:01:00.0: fw 8.5.67516 api 1.15 nvm 8.50 0x8000b6ca 1.3082.0 [8086:15ff] [8086:0000]
[ 17.712815] i40e 0005:01:00.0: MAC address: 00:00:00:00:01:00
[ 17.720161] i40e 0005:01:00.0: FW LLDP is enabled
[ 17.725895] i40e 0005:01:00.0: MSI-X vector reservation failed: -28
[ 17.732893] i40e 0005:01:00.0: MSI-X not available, trying MSI
[ 17.739531] i40e 0005:01:00.0: MSI init failed - -28
[ 17.745178] i40e 0005:01:00.0: MSI-X and MSI not available, falling back to Legacy IRQ
[ 17.755356] i40e 0005:01:00.0: setup of MAIN VSI failed
[ 17.761885] i40e 0005:01:00.0: setup_pf_switch failed: -11
[ 17.768175] i40e: probe of 0005:01:00.0 failed with error -11
[ 17.774939] i40e 0005:01:00.1: Adding to iommu group 12
[ 17.781086] i40e 0005:01:00.1: enabling device (0000 → 0002)
[ 17.805325] i40e 0005:01:00.1: fw 8.5.67516 api 1.15 nvm 8.50 0x8000b6ca 1.3082.0 [8086:15ff] [8086:0000]
[ 17.998681] i40e 0005:01:00.1: MAC address: 00:00:00:00:01:01
[ 18.005909] i40e 0005:01:00.1: FW LLDP is enabled
[ 18.011641] i40e 0005:01:00.1: MSI-X vector reservation failed: -28
[ 18.018644] i40e 0005:01:00.1: MSI-X not available, trying MSI
[ 18.025298] i40e 0005:01:00.1: MSI init failed - -28
[ 18.030959] i40e 0005:01:00.1: MSI-X and MSI not available, falling back to Legacy IRQ
[ 18.041083] i40e 0005:01:00.1: setup of MAIN VSI failed
[ 18.047618] i40e 0005:01:00.1: setup_pf_switch failed: -11
[ 18.053903] i40e: probe of 0005:01:00.1 failed with error -1
Did you ever try to directly reproduce this on Orin AGX devkit with X710?
請問有直接在NV devkit上面用X710複製過這個問題嗎
Hi Wayne,
你好,雖然我們沒在NV devkit上驗證過,但我們明確的知道不會有問題,
因為會發生此問題主要是我們載板上的PCIe device過多,導致IRQ分配不夠造成的
我們在另一片不同版型的載板上(PCIe device比這片載板少),X710是可用的,所以我可以確認NV devkit是OK的
我們目前是JP5.1.1的版本
謝謝
please try this.
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/HR/JetsonModuleAdaptationAndBringUp/JetsonAgxOrinSeries.html?highlight=msi#enabling-more-spi-interrupts-for-pcie
Hi Wayne
謝謝,我們會試試看
