SDRAM CFG means the BCT file, also means the dvfs table in code. It is like below format, and the number of SDRAM should be same as your RAM_CODE straps setting.
[i]# CFG Version 01
Do not edit. Generated by TK1_emc_reg_toolV5.0.18 V5.0.18. Command:
TK1_emc_reg_toolV5.0.18 -i …\param_files\ddr3_256Mx16x4_H5TC4G63AFR_RDA.par 1.262626
-dram_board_cfg 14 -s emc_reg_swz.txt -is_mid_package 1 -round_trip_dly_ps 560.13
-o CFG_792MHz.cfg -b tBKV_RESULT\792MHz_emc_reg.txt -temp_derating 0
Parameter file: …\param_files\ddr3_256Mx16x4_H5TC4G63AFR_RDA.par, tck = 1.26 ns (792.00 MHz)
bkv file: tBKV_RESULT\792MHz_emc_reg.txt
swz file: emc_reg_swz.txt
SDRAM[0].MemoryType = NvBootMemoryType_Ddr3;
SDRAM[0].PllMInputDivider = 0x00000001;
SDRAM[0].PllMFeedbackDivider = 0x00000042;
SDRAM[0].PllMStableTime = 0x0000012c;[/i]
