The Jectpack6.0DP camera cannot be used
Hi, I used IMX334 and IMX219 cameras on JectPack 6.0DP, but ls /dev/video* could not recognize them, and the driver was also confirmed to be turned on. The IMX219 works normally on Jetpack5.1.2. Is there a problem with my settings?
hello 220220996,
did you following Configuring the CSI Connector to enable IMX219?
if yes… may I know what’s the error message reported.
for instance, $ dmesg > klogs.txt
Hi, JerryChang,
This is the dmesg file.
klogs.txt (55.4 KB)
hello 220220996,
it shows probing errors, please double check your hardware connections.
[    9.040332] imx219 9-0010: only 2 data lanes are currently supported
[    9.040343] imx219: probe of 9-0010 failed with error -22
[    9.040379] imx219 10-0010: only 2 data lanes are currently supported
[    9.040382] imx219: probe of 10-0010 failed with error -22
