After deploying the pytorch environment on jetson nano, an error is reported when using pytorch efficiency analysis
make sure PyTorch is built with USE_KINETO=1"“”
AssertionError: Requested Kineto profiling but Kineto is not available,
code show as below
time_test.py (1.6 KB)
Hi @18981275647 , which PyTorch wheel did you install on your Nano?
Can you try running this code in Python3 interpreter?
>>> import torch
>>> print(torch.__version__)
1.10.0
>>> print(torch.__config__.show())
PyTorch built with:
- GCC 7.5
- C++ Version: 201402
- OpenMP 201511 (a.k.a. OpenMP 4.5)
- LAPACK is enabled (usually provided by MKL)
- NNPACK is enabled
- CPU capability usage: NO AVX
- CUDA Runtime 10.2
- NVCC architecture flags: -gencode;arch=compute_53,code=sm_53;-gencode;arch=compute_62,code=sm_62;-gencode;arch=compute_72,code=sm_72
- CuDNN 8.2.1
- Built with CuDNN 8.0
- Build settings: BLAS_INFO=open, BUILD_TYPE=Release, CUDA_VERSION=10.2, CUDNN_VERSION=8.0.0, CXX_COMPILER=/usr/bin/c++, CXX_FLAGS= -Wno-deprecated -fvisibility-inlines-hidden -DUSE_PTHREADPOOL -fopenmp -DNDEBUG -DUSE_KINETO -DLIBKINETO_NOCUPTI -DUSE_XNNPACK -DSYMBOLICATE_MOBILE_DEBUG_HANDLE -DEDGE_PROFILER_USE_KINETO -O2 -fPIC -Wno-narrowing -Wall -Wextra -Werror=return-type -Wno-missing-field-initializers -Wno-type-limits -Wno-array-bounds -Wno-unknown-pragmas -Wno-sign-compare -Wno-unused-parameter -Wno-unused-variable -Wno-unused-function -Wno-unused-result -Wno-unused-local-typedefs -Wno-strict-overflow -Wno-strict-aliasing -Wno-error=deprecated-declarations -Wno-stringop-overflow -Wno-psabi -Wno-error=pedantic -Wno-error=redundant-decls -Wno-error=old-style-cast -fdiagnostics-color=always -faligned-new -Wno-unused-but-set-variable -Wno-maybe-uninitialized -fno-math-errno -fno-trapping-math -Werror=format -DMISSING_ARM_VST1 -DMISSING_ARM_VLD1 -Wno-stringop-overflow, FORCE_FALLBACK_CUDA_MPI=1, LAPACK_INFO=open, TORCH_VERSION=1.10.0, USE_CUDA=ON, USE_CUDNN=ON, USE_EIGEN_FOR_BLAS=ON, USE_EXCEPTION_PTR=1, USE_GFLAGS=OFF, USE_GLOG=OFF, USE_MKL=OFF, USE_MKLDNN=OFF, USE_MPI=ON, USE_NCCL=0, USE_NNPACK=ON, USE_OPENMP=ON,
(note the -DUSE_KINETO
in the config log from torch-1.10.0-cp36-cp36m-linux_aarch64.whl
system
Closed
June 7, 2023, 2:52am
5
