The jetson nx module version installs deepstream and runs an error
I used sdkmanager to install jetpack 4.6.2 version for jetson nx, and selected the kit package, but an error was reported when running deepstream-app -c, the prompt is as follows
Error Code 2: Internal Error (Assertion upperBound != 0 failed. Unknown embedded device detected. Please update the table with the entry: {{1794, 6, 16}, 12653},)
ERROR: Build engine failed from config file
Can you share the full command and full log? Please also provide output of command deepstream-app --version-all.
I found the answer here
Glad to hear that. If there are other problems, you can open a new topic again
