The Jetson Orin Nano is using JetPack 39.2. Upon boot-up, the following error message appears
The Jetson Orin Nano module is using JetPack 39.2. Upon boot-up, the following error message appears. However, the issue disappears after a reboot. Please help us clarify the root cause. Thank you
Providing the serial console or kernel log would help us investigate the issue more effectively. If you have access to the device, please run dmesg and share the output.
The logs are attached. It looks like there might be an issue with the GPU driver loading? Could you please help clarify further
fail log.txt (111.7 KB)
pass log.txt (113.4 KB)
Hi DavidDDD;
any update for this case?
The console logs show the following error. Could you assist in clarifying it?
teraterm_0806_UARTLOG.txt (5.6 MB)
Is this a custom board or NV devkit?
Hi Wayne;
We can reproduce this issue on both the custom board and NV devkit. Power mode is set to 25W.
Is the log that you shared to us based on NV devkit or custom board?
Looks like a log from custom board. Please confirm.
Yes, from custom board.And the following log is form NV devkit,please check it.
teraterm_0804_NV_KITBOARD.txt (3.2 MB)
Hi Wayne:
customer_pinmux_dtsi.zip (6.0 KB)
Here are our modifications.
  1. Modify the default GPIO settings via Pinmux_Config_Template_v1.2.
  2. Only replace the pinmux and GPIO dtsi files in the source tree.
Add configuration for UARTB. Details are as follows:
修改Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/tegra234.dtsi文件
在uarta附近添加
uartb: serial@3110000 {
compatible = “nvidia,tegra234-uart”, “nvidia,tegra20-uart”;
reg = <0x0 0x03110000 0x0 0x10000>;
interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&bpmp TEGRA234_CLK_UARTB>;
resets = <&bpmp TEGRA234_RESET_UARTB>;
status = “disabled”;
修改Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/tegra234-p3768-0000+p3767.dtsi文件
在aliases中添加serial3 = &uartb;
在bus@0中添加
serial@3110000 {
compatible = “nvidia,tegra194-hsuart”;
reset-names = “serial”;
status = “okay”;
修改Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-p3768-0000+p3767-xxxx-nv-common.dtsi文件
修改Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/nv-soc/tegra234-soc-overlay.dtsi
修改这个节点为
serial@3110000 {
//compatible = “nvidia,tegra234-uart”, “nvidia,tegra20-uart”;
interrupts = <GIC_SPI TEGRA234_IRQ_UARTB IRQ_TYPE_LEVEL_HIGH>;
status = “okay”;
want to clarify. Are you booting the device in a high temperature environment?
Could you add extra fan there and see if you see the issue less?’
How many SOM could reproduce this issue on your side?
==>Tested under normal temperature conditions
==>also can reproduce this issue.pleace check the following console log.
==> Currently, all five of our SOMs can reproduce this issue
teraterm_nvkit_0805.txt (943.3 KB)
  1. Do you have more than one devkit carrier board there that could cross check?
  2. Are you using sdkmanager to flash? or you tried to manual flash? We don’t have other users reporting such nvgpu error but only you. I think we need rule out hardware problem.
And also try other kind of NVMe SSD.
    ==> We also met with this with the other NV kit board
    ==>2. The issue occurs both when using the SDK manager approach and manual flash with apt-get install nvidia-jetpack .
    In addition, we rolled back to JetPack 6.2 (36.5) and did not reproduce this issue. However, JetPack 6.2 has issues with 4G module support and uarta.Then JetPack 7.2 has fixed those issue. Could you please provide a patch or other workaround so that we can use the 4G module and uarta properly on version 6.2?
also can reproduce this issue.And update Jetpack 6.2(36.5) test result, console log show the following erro message(both of customer board and NV kit board):026-08-05 20:45:58.517] ld-desktop login: [ 46.768637] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[2026-08-05 20:46:28.932] [ 46.768648] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[2026-08-05 20:46:28.942] [ 46.768652] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[2026-08-05 20:46:28.949] [ 46.768657] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[2026-08-05 20:46:29.308] [ 47.145214] nvgpu: 17000000.gpu pmu_wait_message_cond:664 [ERR] PMU
teraterm_Jp62_nvkit_0806.txt (1.6 MB)
wait timeout expired.
[2026-08-05 20:46:29.314] [ 47.145222] nvgpu: 17000000.gpu pmu_wait_message_cond:664 [ERR] PMU wait timeout expired.
[2026-08-05 20:46:29.325] [ 47.145875] nvgpu: 17000000.gpu ga10b_intr_log_pending_intrs:306 [ERR] Pending TOP[0]: 0x00000004, LEAF[4]: 0x11000000
  1. You could ignore the log on rel-36 because that one does not affect your boot or reboot. They are different from your rel-39 case.
  2. We are not doing any workaround thing for your Jetpack6 in this topic. What we are checking here is why this issue happened on your Jetapck7. If you need any help for your Jetpack6, file another topic.
  3. Is it possible to find out what SOM are reproducing issue on your side while others don’t? I mean, as this issue is not widely reported by other users, it might be related to SOM type.
    Please check cat /etc/nv_boot_control.conf with module that could reproduce issue and module that could not reproduce issue.
also, when issue reproduced, could you check below?
namei -l /lib/firmware/nvidia/ga10b/acr-gsp.data.encrypt.bin.prod
  readlink -e /lib/firmware/nvidia/ga10b/acr-gsp.data.encrypt.bin.prod
  ls -ld /lib/firmware /lib/firmware/nvidia /lib/firmware/nvidia/ga10b
Hi WayneWWW:
ld@ld:~$ namei -l /lib/firmware/nvidia/ga10b/acr-gsp.data.encrypt.bin.prod
f: /lib/firmware/nvidia/ga10b/acr-gsp.data.encrypt.bin.prod
drwxr-xr-x root root /
lrwxrwxrwx root root lib → usr/lib
drwxr-xr-x root root usr
drwxr-xr-x root root lib
drwxr-xr-x root root firmware
drwxr-xr-x root root nvidia
drwxr-xr-x root root ga10b
-rw-r–r-- root root acr-gsp.data.encrypt.bin.prod
ld@ld:~$ readlink -e /lib/firmware/nvidia/ga10b/acr-gsp.data.encrypt.bin.prod
/usr/lib/firmware/nvidia/ga10b/acr-gsp.data.encrypt.bin.prod
ld@ld:~$ ls -ld /lib/firmware /lib/firmware/nvidia /lib/firmware/nvidia/ga10b
drwxr-xr-x 98 root root 28672 Aug 6 11:42 /lib/firmware
drwxr-xr-x 44 root root 4096 Jun 15 16:56 /lib/firmware/nvidia
drwxr-xr-x 2 root root 4096 Jun 15 16:55 /lib/firmware/nvidia/ga10b
ld@ld:~$
Additionally, We made modifications based on the method described in the link below: Jetson R39.2 package ships stale nvidia-cdi-refresh.service - Jetson Systems / Jetson Orin Nano - NVIDIA Developer Forums and after testing over 100 times, we were unable to reproduce the issue.
