hi
I used a jetson orin nx 16G machine and connected to my LAN using wifi.
My router automatically restarts at 2pm every night, but jetson does not automatically connect, only restarts
Please share which Jetpack version you are using. And do you use the default wifi module RTL8822CE?
If you use developer kit(Orin NX module + Orin Nano carrier board), the wifi module is in M.2 Key-E slot and it will be listed in $ sudo lspci command.
