May 5 16:18:37 ishi syslogd 1.5.1: restart.
May 5 16:18:37 ishi dhcpcd[342]: dev: loaded udev
May 5 16:18:37 ishi dhcpcd[342]: no interfaces have a carrier
May 5 16:18:37 ishi dhcpcd[342]: forked to background, child pid 385
May 5 16:18:37 ishi dhcpcd[385]: dummy0: waiting for carrier
May 5 16:18:37 ishi net: dev: loaded udev
May 5 16:18:37 ishi dhcpcd[385]: eth0: waiting for carrier
May 5 16:18:37 ishi net: no interfaces have a carrier
May 5 16:18:37 ishi net: forked to background, child pid 385
May 5 16:18:38 ishi dhcpcd[385]: wlan0: waiting for carrier
May 5 16:18:38 ishi dhcpcd[385]: dummy0: carrier acquired
May 5 16:18:38 ishi dhcpcd[385]: DUID 00:01:00:01:22:7f:62:e2:fe:92:06:80:b1:bc
May 5 16:18:38 ishi dhcpcd[385]: dummy0: IAID 00:af:be:0b
May 5 16:18:38 ishi dhcpcd[385]: dummy0: adding address fe80::5b27:93bd:a288:12d3
May 5 16:18:38 ishi dhcpcd[385]: wlan0: carrier acquired
May 5 16:18:38 ishi dhcpcd[385]: wlan0: IAID 4b:8d:11:e7
May 5 16:18:38 ishi dhcpcd[385]: wlan0: adding address fe80::cb6c:c8f6:441:31ec
May 5 16:18:38 ishi /usr/sbin/gpm[408]: *** info [daemon/startup.c(136)]:
May 5 16:18:38 ishi /usr/sbin/gpm[408]: Started gpm successfully. Entered daemon mode.
May 5 16:18:38 ishi /usr/sbin/gpm[408]: O0o.oops(): [daemon/old_main.c(58)]:
May 5 16:18:38 ishi /usr/sbin/gpm[408]: Could not open /dev/input/mouse0.
May 5 16:18:38 ishi dhcpcd[385]: dummy0: soliciting an IPv6 router
May 5 16:18:38 ishi dhcpcd[385]: wlan0: soliciting an IPv6 router
May 5 16:18:38 ishi dhcpcd[385]: wlan0: soliciting a DHCP lease
May 5 16:18:39 ishi dhcpcd[385]: dummy0: soliciting a DHCP lease
May 5 16:18:40 ishi dhcpcd[385]: eth0: carrier acquired
May 5 16:18:40 ishi dhcpcd[385]: eth0: IAID 4b:8d:11:e9
May 5 16:18:40 ishi dhcpcd[385]: eth0: adding address fe80::14da:9a63:d670:1f5a
May 5 16:18:41 ishi dhcpcd[385]: eth0: soliciting an IPv6 router
May 5 16:18:41 ishi dhcpcd[385]: eth0: rebinding lease of 192.168.0.45
May 5 16:18:41 ishi dhcpcd[385]: eth0: probing address 192.168.0.45/24
May 5 16:18:43 ishi dhcpcd[385]: wlan0: probing for an IPv4LL address
May 5 16:18:46 ishi dhcpcd[385]: eth0: leased 192.168.0.45 for 3600 seconds
May 5 16:18:46 ishi dhcpcd[385]: eth0: adding route to 192.168.0.0/24
May 5 16:18:46 ishi dhcpcd[385]: eth0: adding default route via 192.168.0.1
May 5 16:18:48 ishi dhcpcd[385]: wlan0: using IPv4LL address 169.254.81.182
May 5 16:18:48 ishi dhcpcd[385]: wlan0: adding route to 169.254.0.0/16
May 5 16:18:50 ishi dhcpcd[385]: dummy0: no IPv6 Routers available
May 5 16:18:51 ishi dhcpcd[385]: wlan0: no IPv6 Routers available
May 5 16:18:53 ishi dhcpcd[385]: eth0: no IPv6 Routers available
May 5 16:18:39 ishi kernel: [ 6.694175] EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: (null)
May 5 16:18:39 ishi kernel: [ 6.694188] VFS: Mounted root (ext4 filesystem) on device 8:4.
May 5 16:18:39 ishi kernel: [ 6.695508] devtmpfs: mounted
May 5 16:18:39 ishi kernel: [ 6.695798] Freeing unused kernel memory: 1164K (ffffffc0010fa000 - ffffffc00121d000)
May 5 16:18:39 ishi kernel: [ 6.695821] Freeing alternatives memory: 96K (ffffffc00121d000 - ffffffc001235000)
May 5 16:18:39 ishi kernel: [ 6.698797] btb inv war enabled
May 5 16:18:39 ishi kernel: <30>[ 6.803546] udevd[260]: starting version 3.2.5
May 5 16:18:39 ishi kernel: <30>[ 6.822749] udevd[261]: starting eudev-3.2.5
May 5 16:18:39 ishi kernel: [ 6.888257] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
May 5 16:18:39 ishi kernel: [ 6.897513] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
May 5 16:18:39 ishi kernel: [ 6.907051] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
May 5 16:18:39 ishi kernel: [ 6.918515] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
May 5 16:18:39 ishi kernel: [ 7.003890] CAN device driver interface
May 5 16:18:39 ishi kernel: [ 7.007538] dhd_module_init in
May 5 16:18:39 ishi kernel: [ 7.007566] tegra_net_perf_init: cannot get wifi sclk
May 5 16:18:39 ishi kernel: [ 7.007631] found wifi platform device bcmdhd_wlan
May 5 16:18:39 ishi kernel: [ 7.008724] wifi_platform_get_country_code_map: could not get country_code_map
May 5 16:18:39 ishi kernel: [ 7.008726] wifi_plat_dev_drv_probe:platform country code map is not available
May 5 16:18:39 ishi kernel: [ 7.008750] Power-up adapter 'DHD generic adapter'
May 5 16:18:39 ishi kernel: [ 7.008755] wifi_platform_set_power = 1
May 5 16:18:39 ishi kernel: [ 7.083605] ^I Message RAM Configuration
May 5 16:18:39 ishi kernel: [ 7.083605] ^I| base addr |0x0c312000|
May 5 16:18:39 ishi kernel: [ 7.083605] ^I| sidfc_flssa |0x00000000|
May 5 16:18:39 ishi kernel: [ 7.083605] ^I| xidfc_flesa |0x00000040|
May 5 16:18:39 ishi kernel: [ 7.083605] ^I| rxf0c_f0sa |0x000000c0|
May 5 16:18:39 ishi kernel: [ 7.083605] ^I| rxf1c_f1sa |0x00000300|
May 5 16:18:39 ishi kernel: [ 7.083605] ^I| rxbc_rbsa |0x00000540|
May 5 16:18:39 ishi kernel: [ 7.083605] ^I| txefc_efsa |0x00000780|
May 5 16:18:39 ishi kernel: [ 7.083605] ^I| txbc_tbsa |0x00000800|
May 5 16:18:39 ishi kernel: [ 7.083605] ^I| tmc_tmsa |0x00000c80|
May 5 16:18:39 ishi kernel: [ 7.136433] Release 3.2.0 from 19.12.2014
May 5 16:18:39 ishi kernel: [ 7.142167] net can0: mttcan device registered (regs=ffffff80025fc000, irq=427)
May 5 16:18:39 ishi kernel: [ 7.152216] ^I Message RAM Configuration
May 5 16:18:39 ishi kernel: [ 7.152216] ^I| base addr |0x0c322000|
May 5 16:18:39 ishi kernel: [ 7.152216] ^I| sidfc_flssa |0x00000000|
May 5 16:18:39 ishi kernel: [ 7.152216] ^I| xidfc_flesa |0x00000040|
May 5 16:18:39 ishi kernel: [ 7.152216] ^I| rxf0c_f0sa |0x000000c0|
May 5 16:18:39 ishi kernel: [ 7.152216] ^I| rxf1c_f1sa |0x00000300|
May 5 16:18:39 ishi kernel: [ 7.152216] ^I| rxbc_rbsa |0x00000540|
May 5 16:18:39 ishi kernel: [ 7.152216] ^I| txefc_efsa |0x00000780|
May 5 16:18:39 ishi kernel: [ 7.152216] ^I| txbc_tbsa |0x00000800|
May 5 16:18:39 ishi kernel: [ 7.152216] ^I| tmc_tmsa |0x00000c80|
May 5 16:18:39 ishi kernel: [ 7.204254] Release 3.2.0 from 19.12.2014
May 5 16:18:39 ishi kernel: [ 7.206784] wifi_platform_bus_enumerate device present 1
May 5 16:18:39 ishi kernel: [ 7.216041] net can1: mttcan device registered (regs=ffffff800265e000, irq=428)
May 5 16:18:39 ishi kernel: [ 7.224556] wifi_platform_bus_enumerate device present 0
May 5 16:18:39 ishi kernel: [ 7.231685] F1 signature read @0x18000000=0x17214354
May 5 16:18:39 ishi kernel: [ 7.241572] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
May 5 16:18:39 ishi kernel: [ 7.250022] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
May 5 16:18:39 ishi kernel: [ 7.258503] wifi_platform_prealloc: failed to alloc static mem section 7
May 5 16:18:39 ishi kernel: [ 7.266812] wifi_platform_get_mac_addr
May 5 16:18:39 ishi kernel: [ 7.274302] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
May 5 16:18:39 ishi kernel: [ 7.282641] wl_create_event_handler(): thread:wl_event_handler:124 started
May 5 16:18:39 ishi kernel: [ 7.282648] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc07a7e1a70
May 5 16:18:39 ishi kernel: [ 7.300456] dhd_attach(): thread:dhd_watchdog_thread:125 started
May 5 16:18:39 ishi kernel: [ 7.308163] dhd_attach(): thread:dhd_dpc:126 started
May 5 16:18:39 ishi kernel: [ 7.314826] dhd_attach(): thread:dhd_rxf:127 started
May 5 16:18:39 ishi kernel: [ 7.321062] dhd_deferred_work_init: work queue initialized
May 5 16:18:39 ishi kernel: [ 7.329420] Dongle Host Driver, version 1.201.82 (r)
May 5 16:18:39 ishi kernel: [ 7.329420] Compiled in drivers/net/wireless/bcmdhd on May 3 2018 at 11:56:08
May 5 16:18:39 ishi kernel: [ 7.344285] tegra_sysfs_register
May 5 16:18:39 ishi kernel: [ 7.348695] Register interface [wlan0] MAC: 00:04:4b:8d:11:e7
May 5 16:18:39 ishi kernel: [ 7.362421] dhd_prot_ioctl : bus is down. we have nothing to do
May 5 16:18:39 ishi kernel: [ 7.369927] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 20
May 5 16:18:39 ishi kernel: [ 7.380681] wifi_platform_set_power = 0
May 5 16:18:39 ishi kernel: [ 7.413353] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
May 5 16:18:39 ishi kernel: [ 7.600100] EXT4-fs (sda4): re-mounted. Opts: discard
May 5 16:18:39 ishi kernel: [ 7.616940] EXT4-fs (sda4): re-mounted. Opts: discard
May 5 16:18:39 ishi kernel: [ 7.637700] Adding 8388604k swap on /dev/sda3. Priority:-1 extents:1 across:8388604k SS
May 5 16:18:39 ishi kernel: [ 7.832757] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
May 5 16:18:39 ishi kernel: [ 8.245724] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
May 5 16:18:39 ishi kernel: [ 8.256000] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
May 5 16:18:39 ishi kernel: [ 8.666371] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
May 5 16:18:39 ishi kernel: [ 8.686845] mousedev: PS/2 mouse device common for all mice
May 5 16:18:39 ishi kernel: [ 9.017366] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
May 5 16:18:39 ishi kernel: [ 9.021036]
May 5 16:18:39 ishi kernel: [ 9.021036] Dongle Host Driver, version 1.201.82 (r)
May 5 16:18:39 ishi kernel: [ 9.021036] Compiled in drivers/net/wireless/bcmdhd on May 3 2018 at 11:56:08
May 5 16:18:39 ishi kernel: [ 9.021047] wl_android_wifi_on in
May 5 16:18:39 ishi kernel: [ 9.021051] wifi_platform_set_power = 1
May 5 16:18:39 ishi kernel: [ 9.051031] ip_tables: (C) 2000-2006 Netfilter Core Team
May 5 16:18:39 ishi kernel: [ 9.078779] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
May 5 16:18:39 ishi kernel: [ 9.291376] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
May 5 16:18:39 ishi kernel: [ 9.357733] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 20
May 5 16:18:39 ishi kernel: [ 9.359023] F1 signature read @0x18000000=0x17214354
May 5 16:18:39 ishi kernel: [ 9.362543] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
May 5 16:18:39 ishi kernel: [ 9.363022] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
May 5 16:18:39 ishi kernel: [ 9.413609] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
May 5 16:18:39 ishi kernel: [ 9.455723] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
May 5 16:18:39 ishi kernel: [ 9.455952] Enabling wake69
May 5 16:18:39 ishi kernel: [ 9.456924] wifi_platform_get_mac_addr
May 5 16:18:39 ishi kernel: [ 9.458486] Firmware up: op_mode=0x0005, MAC=00:04:4b:8d:11:e7
May 5 16:18:39 ishi kernel: [ 9.463964] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
May 5 16:18:39 ishi kernel: [ 9.468277] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-e35dbe99
May 5 16:18:39 ishi kernel: [ 9.470568] dhd_interworking_enable: failed to set WNM info, ret=-23
May 5 16:18:39 ishi kernel: [ 9.470770] tegra_sysfs_on
May 5 16:18:39 ishi kernel: [ 9.490023] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
May 5 16:18:39 ishi kernel: [ 9.500422] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
May 5 16:18:39 ishi kernel: [ 9.500436] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
May 5 16:18:39 ishi kernel: [ 9.500781] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
May 5 16:18:39 ishi kernel: [ 9.558943] dhd_ndo_add_ip: ndo ip addr add failed, retcode = -23
May 5 16:18:39 ishi kernel: [ 9.558952] dhd_inet6_work_handler: Adding host ip for NDO failed -23
May 5 16:18:40 ishi kernel: [ 12.255091] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
May 5 16:18:40 ishi kernel: [ 12.256143] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
May 5 16:18:43 ishi kernel: [ 14.966824] protocol 0003 is buggy, dev wlan0
May 5 16:18:45 ishi kernel: [ 16.636028] protocol 0003 is buggy, dev wlan0
May 5 16:18:46 ishi kernel: [ 18.280220] protocol 0003 is buggy, dev wlan0
May 5 16:18:48 ishi kernel: [ 20.289438] protocol 0003 is buggy, dev wlan0
May 5 16:18:50 ishi kernel: [ 22.294548] protocol 0003 is buggy, dev wlan0
May 5 16:19:32 ishi kernel: [ 63.950865] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
May 5 16:19:33 ishi kernel: [ 64.953130] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-12-07 10:50:08 UTC, Version: 55.09 release
May 5 16:19:33 ishi kernel: [ 64.954808] xhci-tegra 3530000.xhci: xHCI Host Controller
May 5 16:19:33 ishi kernel: [ 64.954833] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
May 5 16:19:33 ishi kernel: [ 64.955632] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
May 5 16:19:33 ishi kernel: [ 64.955659] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
May 5 16:19:33 ishi kernel: [ 64.955774] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
May 5 16:19:33 ishi kernel: [ 64.955780] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
May 5 16:19:33 ishi kernel: [ 64.955784] usb usb1: Product: xHCI Host Controller
May 5 16:19:33 ishi kernel: [ 64.955788] usb usb1: Manufacturer: Linux 4.4.38-test xhci-hcd
May 5 16:19:33 ishi kernel: [ 64.955792] usb usb1: SerialNumber: 3530000.xhci
May 5 16:19:33 ishi kernel: [ 64.956088] hub 1-0:1.0: USB hub found
May 5 16:19:33 ishi kernel: [ 64.956113] hub 1-0:1.0: 4 ports detected
May 5 16:19:33 ishi kernel: [ 64.974923] xhci-tegra 3530000.xhci: xHCI Host Controller
May 5 16:19:33 ishi kernel: [ 64.974964] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
May 5 16:19:33 ishi kernel: [ 64.975108] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
May 5 16:19:33 ishi kernel: [ 64.975113] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
May 5 16:19:33 ishi kernel: [ 64.975117] usb usb2: Product: xHCI Host Controller
May 5 16:19:33 ishi kernel: [ 64.975120] usb usb2: Manufacturer: Linux 4.4.38-test xhci-hcd
May 5 16:19:33 ishi kernel: [ 64.975124] usb usb2: SerialNumber: 3530000.xhci
May 5 16:19:33 ishi kernel: [ 64.975350] hub 2-0:1.0: USB hub found
May 5 16:19:33 ishi kernel: [ 64.975370] hub 2-0:1.0: 3 ports detected
May 5 16:19:33 ishi kernel: [ 64.975755] tegra-xotg xotg: otg: host 3530000.xhci registered
May 5 16:19:33 ishi kernel: [ 65.266790] usb 1-2: new high-speed USB device number 2 using xhci-tegra
May 5 16:19:33 ishi kernel: [ 65.311312] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
May 5 16:19:34 ishi kernel: [ 65.336892] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
May 5 16:19:34 ishi kernel: [ 65.336900] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 5 16:19:34 ishi kernel: [ 65.336906] usb 2-1: Product: 4-Port USB 3.0 Hub
May 5 16:19:34 ishi kernel: [ 65.336912] usb 2-1: Manufacturer: Generic
May 5 16:19:34 ishi kernel: [ 65.337394] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
May 5 16:19:34 ishi kernel: [ 65.342380] hub 2-1:1.0: USB hub found
May 5 16:19:34 ishi kernel: [ 65.343147] hub 2-1:1.0: 4 ports detected
May 5 16:19:34 ishi kernel: [ 65.404832] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
May 5 16:19:34 ishi kernel: [ 65.404844] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 5 16:19:34 ishi kernel: [ 65.404851] usb 1-2: Product: 4-Port USB 2.0 Hub
May 5 16:19:34 ishi kernel: [ 65.404858] usb 1-2: Manufacturer: Generic
May 5 16:19:34 ishi kernel: [ 65.405676] hub 1-2:1.0: USB hub found
May 5 16:19:34 ishi kernel: [ 65.406557] hub 1-2:1.0: 4 ports detected
May 5 16:19:34 ishi kernel: [ 65.678789] usb 1-2.2: new low-speed USB device number 3 using xhci-tegra
May 5 16:19:34 ishi kernel: [ 65.788360] usb 1-2.2: New USB device found, idVendor=1a2c, idProduct=0c23
May 5 16:19:34 ishi kernel: [ 65.788370] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 5 16:19:34 ishi kernel: [ 65.788376] usb 1-2.2: Product: USB Keyboard
May 5 16:19:34 ishi kernel: [ 65.788382] usb 1-2.2: Manufacturer: USB
May 5 16:19:34 ishi kernel: [ 65.788554] usb 1-2.2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
May 5 16:19:34 ishi kernel: [ 65.788573] usb 1-2.2: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
May 5 16:19:34 ishi kernel: [ 65.791981] input: USB USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:1A2C:0C23.0001/input/input4
May 5 16:19:34 ishi kernel: [ 65.847007] hid-generic 0003:1A2C:0C23.0001: input,hidraw0: USB HID v1.10 Keyboard [USB USB Keyboard] on usb-3530000.xhci-2.2/input0
May 5 16:19:34 ishi kernel: [ 65.850412] input: USB USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:1A2C:0C23.0002/input/input5
May 5 16:19:34 ishi kernel: [ 65.902936] hid-generic 0003:1A2C:0C23.0002: input,hidraw1: USB HID v1.10 Device [USB USB Keyboard] on usb-3530000.xhci-2.2/input1
May 5 16:19:34 ishi kernel: [ 65.974793] usb 1-2.3: new low-speed USB device number 4 using xhci-tegra
May 5 16:19:34 ishi kernel: [ 66.081867] usb 1-2.3: New USB device found, idVendor=15d9, idProduct=0a41
May 5 16:19:34 ishi kernel: [ 66.081878] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
May 5 16:19:34 ishi kernel: [ 66.081886] usb 1-2.3: Product: USB Mouse
May 5 16:19:34 ishi kernel: [ 66.082104] usb 1-2.3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
May 5 16:19:34 ishi kernel: [ 66.085085] input: USB Mouse as /devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:15D9:0A41.0003/input/input6
May 5 16:19:34 ishi kernel: [ 66.085256] hid-generic 0003:15D9:0A41.0003: input,hidraw2: USB HID v1.10 Mouse [USB Mouse] on usb-3530000.xhci-2.3/input0
May 5 16:19:35 ishi kernel: [ 67.096953] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
May 5 16:19:35 ishi kernel: [ 67.096962] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
May 5 16:21:02 ishi kernel: [ 154.254794] usb 1-2.4: new high-speed USB device number 5 using xhci-tegra
May 5 16:21:03 ishi kernel: [ 154.370232] usb 1-2.4: New USB device found, idVendor=0930, idProduct=6545
May 5 16:21:03 ishi kernel: [ 154.370245] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 5 16:21:03 ishi kernel: [ 154.370254] usb 1-2.4: Product: DataTraveler 2.0
May 5 16:21:03 ishi kernel: [ 154.370261] usb 1-2.4: Manufacturer: Kingston
May 5 16:21:03 ishi kernel: [ 154.370267] usb 1-2.4: SerialNumber: 408D5C15AFB8B070390DD084
May 5 16:21:03 ishi kernel: [ 154.370930] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
May 5 16:21:03 ishi kernel: [ 154.371071] usb-storage 1-2.4:1.0: USB Mass Storage device detected
May 5 16:21:03 ishi kernel: [ 154.375291] scsi host2: usb-storage 1-2.4:1.0
May 5 16:21:04 ishi kernel: [ 155.377621] scsi 2:0:0:0: Direct-Access Kingston DataTraveler 2.0 PMAP PQ: 0 ANSI: 6
May 5 16:21:04 ishi kernel: [ 155.378212] sd 2:0:0:0: [sdb] 15249408 512-byte logical blocks: (7.81 GB/7.27 GiB)
May 5 16:21:04 ishi kernel: [ 155.378514] sd 2:0:0:0: [sdb] Write Protect is off
May 5 16:21:04 ishi kernel: [ 155.378520] sd 2:0:0:0: [sdb] Mode Sense: 45 00 00 00
May 5 16:21:04 ishi kernel: [ 155.378815] sd 2:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
May 5 16:21:04 ishi kernel: [ 155.457290] sdb: sdb1
May 5 16:21:04 ishi kernel: [ 155.458972] sd 2:0:0:0: [sdb] Attached SCSI removable disk
May 5 16:21:19 ishi kernel: [ 170.603469] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
