The leakyRelu layer was implemented by IPlugin, and could not parse layer type IPlugin by caffeParser
When I implementd the leakRelu layer by the IPlugin layer on the TX2 and called caffeParser, it occurs 'assertion ‘mLeakyReluLayer.get()==nullptr’failed ’, I want to ask if it’s because I’ve called this leakyRelu IPlugin layer many times .here is the code that I create leakyRelu IPlugin.
#include "pluginImplement.h"
#include "leakyReluLayer.h"
#include "cudaUtility.h"
#include <fstream>
#include <sstream>
#include <iostream>
using namespace std;
// PluginFactory
nvinfer1::IPlugin* PluginFactory::createPlugin(const char* layerName, const nvinfer1::Weights* weights, int nbWeights)
    assert(isPlugin(layerName));
    if(!strncmp(layerName,"leakyRelu",9))
	assert(mLeakyReluLayer.get()==nullptr);
	mLeakyReluLayer = std::unique_ptr<LeakyReluLayer>(new LeakyReluLayer());
	return mLeakyReluLayer.get();
    else
        assert(0);
        return nullptr;
IPlugin* PluginFactory::createPlugin(const char* layerName, const void* serialData, size_t serialLength)
	mLeakyReluLayer = std::unique_ptr<LeakyReluLayer>(new LeakyReluLayer(serialData,serialLength));
    else
        assert(0);
        return nullptr;
bool PluginFactory::isPlugin(const char* name)
    return (!strncmp(name,"leakyRelu",9));
void PluginFactory::destroyPlugin()
    mLeakyReluLayer.release();
    mLeakyReluLayer = nullptr;
// LeakyRelu Plugin Layer
LeakyReluLayer::LeakyReluLayer(const void* buffer,size_t size)
	assert(size==(7*sizeof(int)));
	const int* d=reinterpret_cast<const int*>(buffer);
	dimsData = DimsCHW{d[0],d[1],d[2]};
	dimsLeakyRelu = DimsCHW{d[3],d[4],d[5]};
	negative_slope = d[6];
Dims LeakyReluLayer::getOutputDimensions(int index, const Dims* inputs, int nbInputDims)
	assert(nbInputDims==1);
	return  DimsCHW(inputs[0].d[0],inputs[0].d[1],inputs[0].d[2]);
int LeakyReluLayer::initialize()
	return 0;
int LeakyReluLayer::enqueue(int batchsize, const void*const *inputs, void** outputs, void*, cudaStream_t stream)
	CHECK(cudaThreadSynchronize());
	int width = dimsData.w();
	int height = dimsData.h();
	int channels = dimsData.c();
	leakyReluLayer((float*)inputs[0], width, height, channels, batchsize, (float*) outputs[0], negative_slope,stream);
	return 0;
void LeakyReluLayer::configure(const Dims* inputs,int, const Dims* outputs,int ,int)
	dimsData = DimsCHW{inputs[0].d[0],inputs[0].d[1],inputs[0].d[2]};
	dimsLeakyRelu = DimsCHW{inputs[0].d[0],inputs[0].d[1],inputs[0].d[2]};
	negative_slope = 0.1;
void LeakyReluLayer::serialize(void* buffer)
	int *d = reinterpret_cast<int*>(buffer);
	d[0] = dimsData.c();
	d[1] = dimsData.h();
	d[2] = dimsData.w();
	d[3] = dimsData.c();
	d[4] = dimsData.h();
	d[5] = dimsData.w();
	d[6] = negative_slope;
size_t LeakyReluLayer::getSerializationSize()
	return 7*sizeof(int);
Guess that you tried to update a plugin pointer multiple times.
If you have more than one leaky relu layers, you can either use different pointer or share the same pointer.
Please don’t over-write the plugin pointer.
