• Hardware Platform (Jetson / GPU):GPU
• DeepStream Version:5.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only):v100
• Issue Type( questions, new requirements, bugs):questions
This is an interesting project,thank you.
But, some of parameters is too difficult to understand,I debug two days, cannot get satisfactory results,I changed pitch, yaw, roll, top-angle ,bottom-angle,width,height,but my 4 surfaces is like the image below:
How can I set the image to 2 rows and 2 columns instead of 4 rows and 1 column
I think ,the correct form should be like the image below:
Additionally,I hope we can give a detailed description of the physical meaning of the parameters in the algorithm, preferably with a simple example, such as changing yaw is to change which area of the picture!
Thank you very much!
