the memory size limit for binding to a texture
Based on testing this limit seems to be (51210241024 + 3) bytes. Here is the testing code
#include <stdio.h>
#define N (512*1024*1024+ 4)
#define CUERR  do{ cudaError_t err;					\
	cudaThreadSynchronize();						\
	if ((err = cudaGetLastError()) != cudaSuccess) {			\
	  printf("ERROR: CUDA error: %s, line %d,file=%s\n", cudaGetErrorString(err), __LINE__, __FILE__); \
	  exit(err);							\
	}}while(0)
texture<float, 1, cudaReadModeElementType> mytex;
__global__ void dummyKernel()
int main()
int device = 1;
  cudaSetDevice(device);CUERR;
float* A = NULL;
cudaMalloc((void**)&A, N); CUERR;
dummyKernel<<<1,1>>>(); CUERR;
cudaBindTexture(0, mytex, A, N); CUERR;
I did not find any document about this limitation. The worst part is there is no error message
when the size is exceeded. Only the next kernel launch will die with “invalid arguments”
and you have no idea what’s happening especially when the next kernel is complicated.
I’m surprised you’re even able to bind a texture that large.
From appendix G.1 of the programming guide:
edit: 1 float = 4 bytes, so the limit seems to be correct
N.
Nico, thanks for the information.
So it is documented! An error message would be nice though when the limit is exceeded.
On the other hand, for int2 texture
texture<int2, 1, cudaReadModeElementType> mytex
I would expect the size limit to be 1GB but it is still 512MB. Is this the expected behavior?
Look at bug: #582591
If I remember correctly CUDA 3.0 should have fixed those limitations.
Obviously it is not fixed since I am using cuda 3.0. I really need the large memory binding in order to run my program with
large input data.
PS. I cannot find your bug report in nvidia developer web site.
Can you check if you can still find it?
Here’s the email I got from nVidia. I’ve spilt the input so I worked around the bug.
" Bug action changed from “Dev - Open - To fix” to “QA - Open - Verify to close”
Please do not reply to this message
The following items have been modified for this Bug:
 - Bug disposition changed from "Open issue" to "Bug - Fixed"
 - Bug action changed from "Dev - Open - To fix" to "QA - Open - Verify to close"
Bug Information
	   Requester: Eyal
 Customer Bug ID:
   NVIDIA Bug ID: 582591
			Date: 8/3/2009 7:49:55 AM
Company/Division: GPU Computing
		Severity: High
		Priority: 1 - High
		Synopsis: Problem accessing textures bound to huge arrays (>2GB) (C1060)
	 Description: Hi,
  My input is usually very big and I use textures to access it from the kernel. When the input is ~2GB of data (I use C1060) the texture access gives me back faulty results when  I try to access high positions in the texture.
Below is a test code and 4 output scenarios.
  Any ideas whats going on?
define PARAM_COUNT 10
texture<float2, 1, cudaReadModeElementType> tex_LargeFloat2;
global void textureKernel( unsigned int iPos, float *fData_d, float *fOutputData1, float *fOutputData2 ) {
for ( unsigned int i = 0; i < PARAM_COUNT; i++ )
	unsigned ii = iPos + i;
	float2 fValue = tex1Dfetch( tex_LargeFloat2, ii );
	fOutputData1[ i ] = fValue.x;
	fOutputData2[ i ] = fValue.y;
// fOutputData1[ i ] = fData_d[ ii * 2 ];
// fOutputData2[ i ] = fData_d[ ii * 2 + 1 ];
// Program main
int
main(int argc, char** argv)
cudaSetDevice(1); // Use the C1060.
unsigned int iDeviceFreeMem = 0, iDeviceTotalMem = 0;
unsigned int iTextureOffset = 69872990; //57,935,200;
unsigned int iSamples = 2001;
unsigned int iSize = 2 * 139676;
iSize *= iSamples;		// iSize = 558,983,352
float *fDummy;
float *fData_h = new float[ iSize ];
float *fData_d = NULL;
float *fOutput_d1 = NULL;
float *fOutput_d2 = NULL;
float *fOutput_h1 = ( float * )malloc( PARAM_COUNT * sizeof( float ) );
float *fOutput_h2 = ( float * )malloc( PARAM_COUNT * sizeof( float ) );
printf( "Size: [%u]\n", iSize );
for ( unsigned int i = 0; i < iSize; i++ )
	fData_h[ i ] = i * 1.f;
cudaMalloc( ( void ** )&( fDummy ), sizeof( float ) );
GPU_CHECK_ERR();
cuMemGetInfo( &iDeviceFreeMem, &iDeviceTotalMem );
printf( "There should be [%u] pairs of float2.\n", iSize / 2 );
printf( "Preparing data for the kernel, memory available: [%u/%u]\n", iDeviceFreeMem, iDeviceTotalMem );
cudaMalloc( ( void ** )&( fData_d ), iSize * sizeof( float ) );
GPU_CHECK_ERR();
// Copy the actual data from the host pointer to the device pointer (cudaMemcpyHostToDevice).
cudaMemcpy( fData_d, fData_h, iSize * sizeof( float ), cudaMemcpyHostToDevice );
cudaMalloc( ( void ** )&( fOutput_d1 ), PARAM_COUNT * sizeof( float ) );
cudaMemset( fOutput_d1, 0, PARAM_COUNT * sizeof( float ) );
GPU_CHECK_ERR();
cudaMalloc( ( void ** )&( fOutput_d2 ), PARAM_COUNT * sizeof( float ) );
cudaMemset( fOutput_d2, 0, PARAM_COUNT * sizeof( float ) );
GPU_CHECK_ERR();
CUDA_SAFE_CALL( cudaBindTexture( 0, tex_LargeFloat2, fData_d, iSize ) );
printf( "Calling the kernel, memory available: [%u/%u]\n", iDeviceFreeMem, iDeviceTotalMem );
textureKernel<<< 1, 1 >>>( iTextureOffset, fData_d, fOutput_d1, fOutput_d2 );
GPU_CHECK_ERR();
printf( "Copying output from the kernel\n" );
cudaMemcpy( fOutput_h1, &( fOutput_d1[ 0 ] ), PARAM_COUNT * sizeof( float ), cudaMemcpyDeviceToHost );
cudaMemcpy( fOutput_h2, &( fOutput_d2[ 0 ] ), PARAM_COUNT * sizeof( float ), cudaMemcpyDeviceToHost );
GPU_CHECK_ERR();
printf( "Kernel results - Offset [%u]:\n", iTextureOffset );
for( int i = 0; i < PARAM_COUNT; i++ )
	printf( "[%d]: [%.3f, %.3f] vs [%.3f, %.3f]\n", i, fOutput_h1[ i ], fOutput_h2[ i ], fData_h[ 2 * ( iTextureOffset + i ) ], fData_h[ 2 * ( iTextureOffset + i ) + 1 ] );
// Now clean up everything ….
cudaFree( fData_d ); cudaFree( fOutput_d1 ); cudaFree( fOutput_d2 );
free( fData_h ); free( fOutput_h1 ); free( fOutput_h2 );
And here are 4 outputs using different values for the <b>iTextureOffset</b> parameter (first column is data from the kernel and second column is from the host):
// All great…
There should be [279491676] pairs of float2.
Preparing data for the kernel, memory available: [4246142976/4294705152] Calling the kernel, memory available: [2010206208/4294705152] Copying output from the kernel Kernel results - Offset [0]:
[0]: [0.000, 1.000] vs [0.000, 1.000]
[1]: [2.000, 3.000] vs [2.000, 3.000]
[2]: [4.000, 5.000] vs [4.000, 5.000]
[3]: [6.000, 7.000] vs [6.000, 7.000]
[4]: [8.000, 9.000] vs [8.000, 9.000]
[5]: [10.000, 11.000] vs [10.000, 11.000]
[6]: [12.000, 13.000] vs [12.000, 13.000]
[7]: [14.000, 15.000] vs [14.000, 15.000]
[8]: [16.000, 17.000] vs [16.000, 17.000]
[9]: [18.000, 19.000] vs [18.000, 19.000]
// This one is still ok…
Preparing data for the kernel, memory available: [4246142976/4294705152] Calling the kernel, memory available: [2010206208/4294705152] Copying output from the kernel Kernel results - Offset [69872900]:
[0]: [139745792.000, 139745808.000] vs [139745792.000, 139745808.000]
[1]: [139745808.000, 139745808.000] vs [139745808.000, 139745808.000]
[2]: [139745808.000, 139745808.000] vs [139745808.000, 139745808.000]
[3]: [139745808.000, 139745808.000] vs [139745808.000, 139745808.000]
[4]: [139745808.000, 139745808.000] vs [139745808.000, 139745808.000]
[5]: [139745808.000, 139745808.000] vs [139745808.000, 139745808.000]
[6]: [139745808.000, 139745808.000] vs [139745808.000, 139745808.000]
[7]: [139745808.000, 139745808.000] vs [139745808.000, 139745808.000]
[8]: [139745824.000, 139745824.000] vs [139745824.000, 139745824.000]
[9]: [139745824.000, 139745824.000] vs [139745824.000, 139745824.000]
// Last item is faulty…
Preparing data for the kernel, memory available: [4246142976/4294705152] Calling the kernel, memory available: [2010206208/4294705152] Copying output from the kernel Kernel results - Offset [69872910]:
[0]: [139745824.000, 139745824.000] vs [139745824.000, 139745824.000]
[1]: [139745824.000, 139745824.000] vs [139745824.000, 139745824.000]
[2]: [139745824.000, 139745824.000] vs [139745824.000, 139745824.000]
[3]: [139745824.000, 139745824.000] vs [139745824.000, 139745824.000]
[4]: [139745824.000, 139745824.000] vs [139745824.000, 139745824.000]
[5]: [139745824.000, 139745824.000] vs [139745824.000, 139745824.000]
[6]: [139745824.000, 139745840.000] vs [139745824.000, 139745840.000]
[7]: [139745840.000, 139745840.000] vs [139745840.000, 139745840.000]
[8]: [139745840.000, 139745840.000] vs [139745840.000, 139745840.000]
[9]: [0.000, 0.000] vs [139745840.000, 139745840.000]
// All items are faulty…
There should be [279,491,676] pairs of float2.
Preparing data for the kernel, memory available: [4246142976/4294705152] Calling the kernel, memory available: [2010206208/4294705152] Copying output from the kernel Kernel results - Offset [69,872,990]:
[0]: [0.000, 0.000] vs [139745984.000, 139745984.000]
[1]: [0.000, 0.000] vs [139745984.000, 139745984.000]
[2]: [0.000, 0.000] vs [139745984.000, 139745984.000]
[3]: [0.000, 0.000] vs [139745984.000, 139745984.000]
[4]: [0.000, 0.000] vs [139745984.000, 139745984.000]
[5]: [0.000, 0.000] vs [139745984.000, 139745984.000]
[6]: [0.000, 0.000] vs [139745984.000, 139746000.000]
[7]: [0.000, 0.000] vs [139746000.000, 139746000.000]
[8]: [0.000, 0.000] vs [139746000.000, 139746000.000]
[9]: [0.000, 0.000] vs [139746000.000, 139746000.000]
-------------------- Additional Information ------------------------ Computer Type: PC System Model Type:
System Model Number:
CPU Type:
Video Memory Type:
Chipset Mfg:
Chipset Type:
Sound Card:
CPU Speed:
Network:
Modem:
North Bridge:
South Bridge:
TV Encoder:
Bus Type: AGP
OS Language:
Application:
Driver Version: 190
System BIOS Version:
Video BIOS Mfg:
Video BIOS Version:
Direct X Version:
Monitor Type:
Monitor 1:
Monitor 2:
Monitor 3:
Video 1:
Video 2:
Video 3:
Resolution:
Color Depth:
Products: other
Application Version:
Application Setting:
Multithreaded Application:
Other open applications:
Release:
OS Details:
Problem Category:
How often does problem occur:
Video Memory Size:
CPUs (single or multi):
RAM (amount & type):
AGP Aperture Size:
Latest Comment update from NVIDIA (8/3/2009 5:06:04 PM):
Will you attach a self contained example and information on the development environment you're using, in particular any special build options or compiler flags? Where is GPU_CHECK_ERR defined? We'll need to be able to reproduce this locally for further investigation.
Some update on this one:
It used to work with old driver/cuda version to bind large memory (> 512 MB) to texture. Here is some data points I collected
driver_version	 cuda_version	 status
190.32				 3.0 beta		   work
195.17				 3.0 beta		   work
195.36.15			 3.0				  fail
265.25				 3.1				   fail
For all version I ran on C1060/S1070.
Can someone from Nvidia please look into this issue? I really need to bind to > 512 MB memory in order to run large input data size
EDIT: I used
texture<float4, 1, cudaReadModeElementType> mytex;
so it should be able to bind >512 MB data
