my kernel program calculating the bounding rect of a gray image(the rect surround all the pixels whose gray level is 255),and then extent the rect for next calculation;because the bounding rect data is stored in device memory,so I write an another kernel to do the extent calculating,but the kernel is very simple and there is no need for any parallelization,so
I call the kernel with grid and block size are all 1,I’m not sure whether it is a good choice,so anyone can tell me other better method to execute a kernel that no need for parallelization?
Below is my code to do bounding rect calculation & rect extent calculation:
extern “C” global void get_mask_rect(const UCHAR alpha, int w,int h,int astep,int * LTRB)
int tx,ty;
if(isInImgRect(w,h,tx,ty))
if(alpha[astepty + tx] == 255)
atomicMin(LTRB,tx);
atomicMax(LTRB+2,tx);
atomicMin(LTRB+1,ty);
atomicMax(LTRB+3,ty);
extern “C” global void extent_roi(const int * LTRB,int w,int h,const int WSZ,int * roi)
int l = LTRB[0] - WSZ;
int r = LTRB[2] + WSZ;
int t = LTRB[1] - WSZ;
int b = LTRB[3] + WSZ;
int BW = ((r-l) + (b-t))/16;
l = max(0,l-BW);
r = min(w-1,r+BW);
t = max(0,t-BW);
b = min(h-1,b+BW);
roi[0] = l;
roi[1] = t;
roi[2] = r-l+1;
roi[3] = b-t+1;
// the code to call kernel
get_mask_rect<<<Gx,Gy,Bx,By>>>(alphaImg,imgW,imgH,imgW,LTRB);
extent_roi<<<1,1>>>(LTRB,imgW,imgH,WSZ,roi);
