The MTU value takes effect after the restart
We modified the MTU value to take effect permanently. However, after the system restarts, the MTU value is still the same as before. How can THE MTU be modified correctly and take effect permanently? thank you
In the /etc/network/interfaces directory, add MTU 9000
For dynamic IP case, the MTU is from dhcp.
You may need to configure /etc/dhcp/dhclient.conf.
thanks,I configured a static IP address
