The network generated by the module itself will occasionally become 10M
I use OrinNX 16GB SOM , I find that the network generated by the module itself will occasionally become 10M ,at room temperature.Could you please help to check this issue for us? Thanks a lot.
Please execute sudo jetson_clocks and check if it helps. This enabled most hardware engines at maximum clocks.
Are you talking about ethtool says it is in 10M occasionally?
