The NVIDIA AGX Orin cannot be started normally after system flashing
The system gets stuck at this point after normal programming. How can I solve it
Hello @1533928007!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
Hi @1533928007, we’re seeing the Jetson get stuck after normal programming during UEFI firmware initialization.
The boot log shows:
ERROR: camera-ip/isp5/isp5.c:2031 [isp5_pm_init] "ERROR: Failed to turn isp1 power on"
BUG: core/init/init.c:86 [init_all] "*** FIRMWARE INIT FAILED AT LEVEL 95 ***"
Could you share more details about the programming process you used?
Specifically:
  • Exact Jetson module/SKU
  • JetPack/L4T version
  • Flash command used
  • Board config used
  • Whether this is an NVIDIA devkit carrier or a custom carrier
  • Any custom MB1/BCT/BPMP/UEFI/kernel DTB files used
  • Whether the board has EEPROM or fixed board ID configuration
  • Full flash log, if available
We want to confirm whether this is caused by a BSP/config mismatch, custom carrier adaptation issue, or something in the power/boot firmware setup.
Tobias Fonseca
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
