The oem file of xavier nx
Hello, why can’t I find the oem file of xavier nx, can you send me a link? I want to find the software number of I2C in this document
Supposed you set the wrong filter, you should be able to find them by selec product setting “Jetson Xavier NX”, see Jetson Download Center | NVIDIA Developer
I have also searched for the method you mentioned, and I have not found it. Is the file command method of xavier nx different from other ones?
What I’m looking for is the I2C interface mapping of Xavier nx, a file like the picture
Hi, the OEM Design Guide is not available currently, you can check the pinmux sheet and module datasheet for the info.
Hi, the linkage in DLC is as below:
https://developer.nvidia.com/jetson-xavier-nx-product-design-guide
