The official performance specifications and the publicly available official MV3DT configurations are inconsistent
Hello, I noticed that your official performance table lists 640x640, but the publicly available NGC model, ONNX, and official MV3DT configuration all use 544x960. I’m unsure if this is a mistake on your part or if you have your own internal test model.
Thanks for report this. I will check and feedback later.
You are right, The Peoplenet 2.6.3 Inference resolution is 3x544x960. We will correct the documentation in upcoming release.
Thank you for your reply. I have another question. I followed the official procedure to process 12 video streams using PeopleNet 2.6.3 + MV3DT, and the resulting frame rate was around 393, which is better than the 363 you measured in your official test. I’m wondering if this is normal, or if there’s something wrong with my testing method that’s causing the error.
  1. How did you get the data? Is the Jetson Thor power max and frequency locked when you run your test?
  2. The FPS record in Performance is the case of 4 local videos.
1.yes,the NV Power is MAXN。Jetson Thor’s maximum power and frequency are locked.
2.We ran Deepstream + PeopleNet 2.6.3 + MV3DT according to the tutorial.Shouldn’t it be route 12?
There are two samples in DeepStream/src/apps/reference_apps/deepstream-tracker-3d-multi-view at main · NVIDIA/DeepStream, 4 cameras dataset and 12 cameras dataset.
Hello, I ran the test using 12 channels and achieved 390 FPS. Could you tell me what the official figures are? I believe we successfully ran the test; here are our screenshots.
Close this topic for duplicated topic 性能测试跑官方的Deepstream + PeopleNet 2.6.3 + MV3DT 12cam 的数据 - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
