I found that my earlier crash with 2 workers wasn’t a memory issue – it was a corrupted CUDA driver (syncpoint allocation failures) / moving into some corrective actions - stay tuned :)
Thor can handle multiple streams.
Do you meet the same issues when using num_ctx=4096?
In our previous experiment, Ollama allocates memory incrementally, and it might causes issues in the case that memory is tight.
Have you tried other LLM frameworks like vLLM?
Q1 on Ollama with gemma3:27b → failing (EOF crashes, num_ctx=32768 too large for Jetson allocator)
Decided to migrate to vLLM → installed it, downloaded gemma-3-27b-it (55 GB)
vLLM failed to start → libtorch_cuda.so: cannot open shared object file
Root cause: pip install vllm pulled CPU-only PyTorch (torch 2.9.1+cpu) because there are no CUDA aarch64 PyPI wheels for Python 3.12 on Jetson
Installed CUDA toolkit 13.0 (nvcc now available at /usr/local/cuda-13.0/bin/nvcc) but still no CUDA torch available
vLLM cannot currently run on this Thor system until PyTorch with CUDA 13 support for aarch64 is available. NVIDIA or PyTorch.org may eventually publish aarch64+CUDA13 wheels for Python 3.12
