I’m super keen to use nsight to work on my 3d engine, unfortunately when I start the nsight graphics debugger it errors immediately with a pointless error.
After a bunch of trial and error, I’ve whittled it down to a simple case/repro steps;
- Create a new VS (2013) WinForms project (.NET 4.5)
- Set it to x86 and ‘Start Graphics Debugging’, it works. Now set it to x64 and ‘Start Graphics Debugging’ it errors immediately with ‘The operation completed succesfully’ :(
I hope I’ve just missed something obvious and that x64 winforms apps will ‘just work’
Cheers,
Chad
I am able to reproduce a similar issue (I get an “access denied”), but just making sure I did the same as you in #2, do you go to the project properties and set the “Platform target:” drop down under “Build” to x64?
Correct, project properties > Build > Platform target to x64. After setting this (and building) I’m now unable to get nsight to attach, it returns ‘The operation completed successfully’ error (which a quick Google shows is a bug in the error handling code inside something related to GDI).
So the issue is related to the bitness (x86 vs x64) and having WinForms/GDI in the mix somehow…
In order to load a x64 .NET app which uses WinForms with nsight -
http://www.btbsoft.org/Tutorials/view/4/Debugging-64bit-managed-applications-with-PIX
It’s the same trick people use to get Microsoft’s PIX debugger to launch x64 apps.
Basically, it’s a C++/CLI bootstrap app which you launch with nsight and it in turn launches your main application in the same AppDomain.
Happy debugging :)
