The operation doesn't show % efficiency
__global__ void sortBlocks(int *a)
	int i = 2;
	__shared__ int temp[THREADS];
	while (i <= THREADS)
		if ((threadIdx.x %i) == 0)
			int index1 = threadIdx.x + (blockIdx.x * blockDim.x);
			int endIndex1 = index1 + i / 2;
			int index2 = endIndex1;
			int endIndex2 = index2 + i / 2;
			int targetIndex = threadIdx.x;
			int done = 0;
			while (!done)
				if ((index1 == endIndex1) && (index2 < endIndex2))
					temp[targetIndex++] = a[index2++];
				else if ((index2 == endIndex2) && (index1 < endIndex1))
					temp[targetIndex++] = a[index1++];
				else if (a[index1] < a[index2])
				else
				if ((index1 == endIndex1) && (index2 == endIndex2))
					done = 1;
		__syncthreads();
		a[threadIdx.x + (blockIdx.x * blockDim.x)] = temp[threadIdx.x];
		__syncthreads();
		i *= 2;
I know that removing the % from the CUDA operation will speed up the operation.
I did not use % by replacing “if ((threadIdx.x %i) == 0)” with “if ((threadIdx.x &(i -1)) == 0)”, but the computation time did not get faster. What is the reason?
And can you figure out how to reduce computation time like this?
Only if that is a bottleneck in your code. Your code looks memory bound, and there may be other issues. The CUDA profiler can help you identify bottlenecks in your code, I would suggest spending some quality time with it. It’s also a good idea to read the Best Practices Guide.
