Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
[*] 4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
[*] Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: NVIDIA GeForce RTX 4060
- Driver Version: 570.124.04
Topic Description
Detailed Description
The first error is :
I create a camera_view to get camera rgb data and depth data,the camera is created in USD file.
The camera rgb_camera_prim_path=“/World/World0/G1/G1/link_pitch_head/Head_Camera_01”
The code to create camera_view is follow:
camera_view = CameraView(
name=“camera_prim_view”,
camera_resolution=(width,height),
prim_paths_expr=rgb_camera_prim_path,
output_annotators=[“rgb”, “depth”],
Then i run world.reset() once and run world.step() in while loop.
After world.step(), i get camera_view local position and rotation by camera_local_positions, camera_local_quaternions = camera_view.get_local_poses().
The position data is the same with UI,but the quaternions data is not.
The second error is :
I use follow code to get prim transform:
prim_path = “/World/scene/scene/_11_banana”
prim = get_prim_at_path(banana_prim_path)
xform = UsdGeom.Xformable(prim)
world_transform = xform.ComputeLocalToWorldTransform(0)
object_position_world = np.array(world_transform.ExtractTranslation())
rot_matrix = np.array(world_transform.ExtractRotationMatrix())
the position is the same with UI,
but the euler from rot_matrix is the opposite number with the euler from UI.
What caused this situation? And which value is right?
Steps to Reproduce
(Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
