The orin failed in the uefi stage
I have a orin module(commercial module),it failed in the uefi stage.The orin devkit(som use with my own board) boot successfully with same image.logs as below:
Loading driver at 0x0080585A000 EntryPoint=0x00805860618 SmbiosDxe.efi
add-symbol-file /home/csu/code/develop_nvidia_uefi/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/DevicePathDxe/DevicePathDxe/DEBUG/DevicePathDxe.dll 0x805848000
Loading driver at 0x00805847000 EntryPoint=0x008058531D8 DevicePathDxe.efi
add-symbol-file /home/csu/code/develop_nvidia_uefi/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/MdeModulePkg/Universal/EbcDxe/EbcDxe/DEBUG/EbcDxe.dll 0x80583B000
Loading driver at 0x0080583A000 EntryPoint=0x008058423D0 EbcDxe.efi
add-symbol-file /home/csu/code/develop_nvidia_uefi/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/RcmDxe/RcmDxe/DEBUG/RcmDxe.dll 0x805532000
Loading driver at 0x00805531000 EntryPoint=0x008055357B0 RcmDxe.efi
Error: Image at 00805531000 start failed: Not Found
remove-symbol-file /home/csu/code/develop_nvidia_uefi/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/RcmDxe/RcmDxe/DEBUG/RcmDxe.dll 0x05532000
add-symbol-file /home/csu/code/develop_nvidia_uefi/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/PlatformToDriverConfiguration/PlatformToDriverConfiguration/DEBUG/PlatformToDriverConfiguration.dll 0x805532000
Loading driver at 0x00805531000 EntryPoint=0x00805535FA0 PlatformToDriverConfiguration.efi
add-symbol-file /home/csu/code/develop_nvidia_uefi/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/CapsuleUpdatePolicyDxe/CapsuleUpdatePolicyDxe/DEBUG/CapsuleUpdatePolicyDxe.dll 0x8054B0000
Loading driver at 0x008054A0000 EntryPoint=0x008054B3698 CapsuleUpdatePolicyDxe.efi
add-symbol-file /home/csu/code/develop_nvidia_uefi/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/EepromDxe/Eeprom/DEBUG/EepromDxe.dll 0x805528000
Loading driver at 0x00805527000 EntryPoint=0x0080552C424 EepromDxe.efi
Cvm Eeprom Product Id: 699-13701-0004-500 G.0
Cvb Eeprom data validation failed(Success)
add-symbol-file /home/csu/code/develop_nvidia_uefi/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Tegra/T234/Drivers/UsbFirmwareDxe/UsbFirmwareDxe/DEBUG/UsbFirmwareDxe.dll 0x8053A4000
Loading driver at 0x008053A3000 EntryPoint=0x008053A76A4 UsbFirmwareDxe.efi
add-symbol-file /home/csu/code/develop_nvidia_uefi/nvidia-uefi/Build/Jetson/DEBUG_GCC5/AARCH64/Silicon/NVIDIA/Drivers/BpmpIpc/BpmpIpcDxe/DEBUG/BpmpIpcDxe.dll 0x80551A000
Loading driver at 0x00805519000 EntryPoint=0x008055215D8 BpmpIpcDxe.efi
HspDoorbellEnableChannel: Waiting for HSP Doorbell Channel Enabled.
orin_msg.log (91.1 KB)
Complete print information
Hi jasonGrave,
If the devkit could boot successfully but your custom board could not when they are using the same image.
You could refer to the following link to modify configuration for EEPROM.
Jetson AGX Orin Platform Adaptation and Bring-Up - Modifying the EEPROM
