The Orin module fails to start using the SD card
I swiped “Jetson-nX-JP501DP-SD-card-image.zip” into my SD card. Then I went into the system and changed the extlinux.conf configuration file in boot. When I booted up Orin could not enter the operating system, the serial port printed the following error:
"[10:24:24.172]recive←◆[ 9.455521] nvidia: loading out-of-tree module taints kernel.
[10:24:24.241]recive←◆[ 9.526809] using random self ethernet address
[ 9.526950] using random host ethernet address
[10:24:24.404]recive←◆[ 9.688179] 1 fixed-partitions partitions found on MTD device spi6.0
[ 9.688371] Creating 1 MTD partitions on “spi6.0”:
[ 9.688512] 0x000000000000-0x000004000000 : “Whole_flash0”
[10:24:24.729]recive←◆[ 10.014249] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[10:24:24.810]recive←◆[ 10.095324] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 10.095574] OF: graph: no port node foun
[10:24:24.834]recive←◆d in /i2c@c240000/ucsi_ccg@8/connector@0
[10:24:25.458]recive←◆[ 10.743277] using random self ethernet address
[ 10.743431] using random host ethernet address
[10:24:33.810]recive←◆[ 19.094588] Please complete system configuration setup on the serial port provided by Jetson’s USB device mode connection. e.g. /dev/ttyACMx where x can 0, 1, 2 etc"
Please just wait for me to reply your question in previous thread…
Ok, thank you very much.
Waiting for your reply
