The Orin NX report error when burning 36.2 system.Do you know the reason?
I use the following command to burn Orin NX.
$sudo tar xvpf ./Jetson_Linux_R36.2.0_aarch64.tbz2
$sudo tar xvpf ./Tegra_Linux_Sample-Root-Filesystem_R36.2.0_aarch64.tbz2 -C Linux_for_Tegra/rootfs/
$cd Linux_for_Tegra/
$sudo ./apply_binaries.sh
$sudo ./tools/l4t_flash_prerequisites.sh
$sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1   -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml"   --showlogs --network usb0 jetson-orin-nano-devkit internal
Then error is reported and the following attachment is the log.Do you know the reason?
burnerror.txt (17.8 KB)
新版的config檔的路徑已經不是t186ref,現在改成generic
麻煩看一下文件…
问题解决了,太感谢了!
